Previous in Forum: Seal Oil Level Increase   Next in Forum: ABB Program Using Arrays
Reduction in MDMT
05/04/2010 8:24 AM
I am calculating MDMT for shell ID=915mm thickness 10mm, Material SA-516 Gr.70
I saw ASME UCS66 which says to calculate MDMT by looking at Fig UCS66.1. It also says to calculate REDUCTION IN MDMT by first finding ratio which is
(tr x E)/ (tn-c)
My question is that whats the purpose of calculating Reduction in MDMT? whats the interpretation?
Re: Reduction in MDMT
05/04/2010 8:41 AM
05/05/2010 7:09 AM
Increasing the thickness of any pressure part from its min. required tr to the adopted/nominal tn (due to corrosion/erosion allowance, threaded, mill tolerances, … etc.) will lead to an increasing of MDMT (disadvantage). And the ASME try to compensate that disadvantage by adding a correlation factor represents the Reduction in MDMT which depends on the ratio (tr x E)/ (tn-c).
See CR Thread Re: Impact Tests for Pressure Vessels.
05/06/2010 12:44 AM
Say the reduced MDMT came 64 degree F.. and the MDMT came to be -20 degree F..
so for adjusted MDMT we have 44 degree F?? :s
05/06/2010 2:03 PM
Based on your assumption (calculated reduction is 64 oF and MDMT is - 20 oF), the adjusted MDMT shall be equal to - 20 - (64) = - 84 oF
05/06/2010 6:14 AM
my interpretation is that you can use a material at a lower temperature if the stress ratio is below a certain value.
have a look at this page:
http://www.gowelding.com/weld/fracture/impact.html
hope this help
S
corrosion prevention & control
Abdel Halim Galala (2); Anonymous Poster (2); strider6 (1)
