Previous in Forum: Generator Fails to Produce Power   Next in Forum: Fuji VFD Control Questions
8 comments
SCR vs Diode Based Rectifiers
11/06/2012 2:02 AM
Dear all,
Request for your inputs -
1. What is the difference between a Thyristor and a Diode based rectifier. Which is better?
2. What is the efficiency of a Thyristor and a Diode based rectifier?
3. Is there any method by which we can increase the loading of a rectifier?
4.How to check the voltage drop between the electrodes or the cathode and the anode?
Your response will be highly appreciated!
Thank you,
Regards,
Rooney
Good Answers: 34
Re: SCR vs Diode Based Rectifiers
11/06/2012 2:51 AM
Please bear with me, if I am not able to articulate well.
1. Thyristor is a triggered one-way switch, its duty cycle can be controlled. Diode is a one-way device as long as anode is positive with respect to cathode.
2. Efficiency will depend on circuit design.
3. Yes. Connect more loads to it.
4. Connect a volt meter on suitable range, across both.
Personally, I don't post to threads to garner appreciation.
11/22/2012 1:34 AM
correct comment ,i am agree on these comments..thanks for comment.
11/06/2012 3:20 AM
A1) It's a bit like asking, "Which is better, a car, or a pick-up van?". They do different jobs.
A2-4) See #1↑.
11/06/2012 6:08 AM
I am interested....Please tell me more about this...how did you call it.... 'pick-up van'?
Would it be compatible with pulse and glide operating techniques?
Good Answers: 804
11/06/2012 9:45 AM
'pick-up van'
I had one of those in the '70s. It's a tricked out van in which you pick up chicks. Mine had a matress in the back.
11/06/2012 1:35 PM
OHHH! I think I know what type you mean.
It's the 'If this van is a-rockin' don't come a-knockin'....and this van will always be a-rockin' type, right?
11/07/2012 12:33 AM
the scr (thyrister) is full wave controller rectifier ...it has high efficiency and better then diode rectifier ...which is uncontrolled rectifier ..it has poor efficiency ..
11/21/2012 6:31 AM
Sorry, nothing like that.
To the OP
How to measure the voltage drop on a diode
What is the input supply to the diode...
If it is AC, then the answer is... u cannot do it with a multimeter.
If it is dc, just measure across the diode when it is forward biased.
If u select diode range on your DMM and connect a diode across it, with red to anode, it will show the forward voltage nearly 0.4 to 0.6 volt
Gajanan Phadte
Register to Reply 8 comments
binod panthee (2); gmphadte (1); Joshi (1); JRaef (1); PWSlack (1); truth is not a compromise (2)
