Previous in Forum: Summer Cooling   Next in Forum: Minimum Distance to Be Left Between Welded Joints in Pressure Vessels
Pressure Gauge
11/18/2012 10:10 PM
Same Pressure gauge can be used for both pneumatic test and pressure test ?or any variation in pressure gauge selection against type of test
Re: Pressure gauge
11/18/2012 10:24 PM
Generally yes, so long as the two pressures are fairly near to each other, and preferably near mid range of the gauge.
Re: Pressure gauge
11/18/2012 11:02 PM
thank you
Re: Pressure Gauge
11/18/2012 10:50 PM
You might need an isolator.
Re: Pressure Gauge
11/19/2012 3:48 AM
...and make sure the hydraulic test precedes the pneumatic one. The hydraulic test takes place at the higher pressure, BTW...
Register to Reply 4 comments
lyn (1); PWSlack (1); suvarna_mendu (1); Tornado (1)
