Previous in Forum: Tis the Season   Next in Forum: TSSA Pneumatic Specs
50 comments
Another "What-If" Scenario - Guns for Jetpacks?
11/21/2012 9:26 AM
The question that was asked is:
"Is it possible to build a jetpack using downward firing machine guns?"
One blogger took the time to break down the scenerio and throw some math behind it here: http://what-if.xkcd.com/21/
For starters, they analyze just one AK-47 to find that the thrust would only be enough to lift Kris.
There's a lot more meat and potatoes to the whole article, so I'll let you read through it, but I'm a bit curious as to what everyone's take on this is (serious, or not serious).
DISCLAIMER: Please don't try to use guns as jetpacks. It will more than likely definitely end poorly.
NOTE: If you can't go to the page, send me a PM and I'd be more than happy to copy+paste the article into a private message for you!
The first law of thermodynamics is you do NOT talk about thermodynamics.
Re: Another "What-If" Scenerio - Guns for Jetpacks?
11/21/2012 9:32 AM
"Is it possible to build a jetpack using downward firing machine guns?" Yes. With enough money, just about anything can be built.
"Will my jetpack that uses downward firing machine guns lift me into the air?" No. Even a .50BMG would be insufficient reaction to lift itself off the ground for more than, perhaps, a few seconds, this complicated by the fact than ammunition (fuel in this case, I suppose) adds so much weight to the scenario.
11/26/2012 10:28 AM
I agree, the weight of the ammunition by itself would be too much. Furthermore, it wouldn't be cost effective. A couple rounds would be as much as a gallon of jet fuel.
In the early space program it was put on the table the idea of blasting several nuclear blasts under a huge plate of iron to launch a manned craft into space but shelved in place of other ideas. This idea had been theorized as conceivable by physicists and later used in a science fiction novel.
11/26/2012 11:00 AM
'.....In the early space program it was put on the table the idea of blasting several nuclear blasts under a huge plate of iron to launch a manned craft into space but shelved in place of other ideas....'
This went beyond theoretical.
In an early US nuclear test, either Pascal A or B, a roughly 2000 lb steel blast door was lauched at about 6 times escape velocity. This was pre-Sputnik, so it puts into question the 'first artificial earth satellite' record into question (no one makes the cleaim to emphatically though).
Re: Another "What-If" Scenario - Guns for Jet-packs?
11/26/2012 11:05 AM
At six times the escape velocity I think it is safe to say that the remnants of this plate did escape Earth's gravitational pull and did not go into orbit. Sputnik still retains the prize for the first artificial satellite.
11/26/2012 11:39 AM
At 6 times escape velocity, I think there is a strong possibility that it did not stay together as one piece traveling throught the atmosphere.
I think it probably burned upin the atmosphere.
But if it didn't, how far around does it have to go, for you to conside it an artificial satellite?
It is really difficult to launch anything from earth and get it to orbit without corrections to trajectory once you have left the ground.....so unless the atmosphere made some hellacious corrections, none of that stuff was a satellite for long.
11/26/2012 4:31 PM
There was talk as well as experiments of using a upside down dish and shooting a laser into it.
The laser would heat up the air and moisture and propel it.
The had stablization problems. but when they put a spin on it that helped.
What really help was a guide rod running through the middle
Good Answers: 918
11/27/2012 1:16 PM
"What really help was a guide rod running through the middle"
They stole that idea from the Estes model rocket launchers!
11/27/2012 1:32 PM
I saw a video clip of it.
Good Answers: 145
11/21/2012 9:33 AM
A jet pack would need to go straight up and therefore thrust would have to exceed weight. With "real" ammo I doubt that the thrust could exceed the weight on anything that would resemble a usable platform.
I have heard of warthogs having a considerable decrease in forward speed when they get mad and express their anger. Thus, a tiny amount of support for the theory, but not enough to make it fly.
11/21/2012 9:35 AM
From the article:
But there's a problem: Ammunition.
An AK-47 clip holds 30 rounds. At ten per second, we'll get a measly three seconds of acceleration. We can improve this with a larger magazine-but only up to a point.
It turns out there's no advantage to carrying more than about 250 rounds of ammunition. The reason for this is a fundamental and central problem in rocket science: Fuel makes you heavier.
Each bullet weighs 8 grams, and the cartridge (the "whole bullet") weighs over 16 grams. If we add more than about 250 rounds, the AK-47 is too heavy to take off.
This suggests our optimal craft comprises a large number of AK-47s (a minimum of 25 but ideally at least 300) carrying 250 rounds of ammunition each. The largest versions of this craft could accelerate upward to vertical speeds approaching 100 meters per second, climbing over half a kilometer into the air.
Re: Another "What-If" Scenario - Guns for Jetpacks?
11/21/2012 10:05 AM
XKCD has made another interesting and fun article.
However, I do think that an important point has been missed here. I'll overlook the error that by hurling bullets this is by definition not a gaseous jet and hence not a jet pack. The thrust control of a jet pack must be gradually adjustable to allow for a controlled landing. If the goal is to just launch a person or squirrel to their death then the normal operation of a gun will work much more efficiently.
11/21/2012 10:07 AM
"If the goal is to just launch a person or squirrel to their death then the normal operation of a gun will work much more efficiently."
Snore!
11/21/2012 10:12 AM
There just ain't hardly enough meat on a squirrel to justify killin' it in the first place.
11/26/2012 12:55 PM
I've eaten squirrel and it's not bad. It also depends on where you get them. I've seen grey squirrels as big as cats that are well fed on acorns and the chipmunks as big as the squirrels. Those digger squirrels you see along the roads don't count.
11/26/2012 2:07 PM
What did Kris think of this?
Re: Another "What-If" Scenario - Guns for Jet packs?
11/21/2012 11:45 AM
Glad I didn't wake you with an engineering perspective. Sleep tight little kitty.
11/26/2012 11:12 AM
The bullets don't need a projectile associated with them to give the same results.
11/21/2012 10:08 AM
Loaded AK-47 rifle 4.78 kg. Projectile 8 grams. Muzzle energy 2,460 J.
I come up with about 40 joules of recoil energy per shot fired, and this for a very short period of time.
It'll never fly.
Good Answers: 918
11/21/2012 11:24 AM
Nevertheless, I do not want to be one of the journalists spectating.
11/21/2012 9:38 AM
Yosemite Sam says,
"Yer darn Tootin"
Re: Another "What-If" SCENERIO - Guns for Jetpacks?
11/21/2012 10:02 AM
First, this is a ridiculous idea, but might aid slightly in thinning the gene pool.
The weight of sufficient ammunition to sustain rapid fire long enough to lift the vehicle
would be so large that this thing would never get off the ground.
Wait, let's use helium bullets.
11/21/2012 10:06 AM
Whoever would actually attempt making a jetpack out of guns would definitely be in line for some sort of Darwin award, that's for certain
The creator of the article claimed that the loaded AK-47 had a thrust-to-weight ratio of about 2. Wouldn't a large group of guns firing simultaneously be enough to cause lift-off?
11/21/2012 10:15 AM
Simply do it without the actual bullets (slugs) and you have a solid fuel rocket powered by small charges injected sequentially.
This technique has been tried before in the early days of rocketry by the likes of Clarence N Hickman who lost some fingers during such an experiment.
(So if you find any fingers...)
11/21/2012 10:19 AM
But the recoil has to do with moving the mass (bullet). And the recoil is use to discharge and reload.
I get the feeling that was no experiement, how old was he, 15-16?
11/21/2012 10:23 AM
Whoever he is, he helped create the Bazooka. The guy must've had a real fondness for explosions and loud noises (and a low fondness of keeping all of his limbs).
11/21/2012 10:25 AM
I understand they just kept getting in the way anyways
11/21/2012 11:38 AM
Whoever he is?
This guy had quite a bio, that was a little diverse.
It reminds me, I worked with a guy that was with a company that was one of my clients, his background was that he was a Weapons Engineer for the then USSR.
He immigrated to this country back in the early 80's and because of the security risks, he could not get a job here in his field. So he's now a process engineer making cheese and butter. As he told me shaking his head.
I told him, yeah, I see the connection.
11/21/2012 11:40 AM
I meant no disrespect!
Seems this fellow has quite the diverse repertoire under his belt!
11/21/2012 11:47 AM
none taken, but I did get scratched earlier ...... I had revised by adding to my post, it had reminded me that people like this do have some interesting stories.
11/21/2012 10:29 AM
Take your criticism to NASA and try to convince them that the Atlas 5 rocket engine would work better with the addition of lead slugs...
<slaps head with furry paw>
11/21/2012 10:38 AM
I didn't re-think, I'm not quite sure what you mean, but I thought about it.....
There are three types of systems
  • Recoil Systems
  • Blowback systems
  • Gas mechanisms
But as far as the Atlas Rocket, now your talking more than a self contain small charges injected sequentially, aren't you.........
11/21/2012 10:45 AM
Cheezes,
I'm talking about the principle.
In order for it to work you need to get rid of the extraneous mass of the slugs and improve the combustion.
This effectively moves it towards becoming a solid fuel rocket, which is self evidently feasible.
I realise the whole thread is bonkers...
I was merely trying to illustrate that it's actually not too far from the development of the solid fuel rocket.
I think I'll give up and get back to my cat nap.
11/21/2012 10:48 AM
I'm sure we are are familair with the basics physics of rocketry.
Yes, a nap may be over due.
11/21/2012 10:48 AM
I fully expect this thread to go at least a little off topic (maybe more, who can guess). The overall feasability of getting off the ground with a gun increases as you decrease the mass of the gun, so it's obviosuly the right idea. There are quite a few extraneous parts of a gun that are there for user operation that could also be eliminated, such as the barrel.
11/21/2012 11:01 AM
On another thread here, believe or not, we were talking about some things simular about the GAU-8/A Avenger Gatling gun on the A-10 Avenger, About it affecting it's flight.
Plus the couple of tons of shells it requires.......
I think Capt Moosie had some good input.
11/21/2012 7:00 PM
As long as we are down this path, we might as well add the C130 gunship to our consideration.
Firing 105mm, 40mm, and 20mm contiually out the port side certainly has an effect on position, though aside from the concussive jarring effect, I'm not sure if anyone other than the pilot, navigator and fire control (sorry for the guesses on the titles here) would have be able to quanify it.
11/21/2012 7:27 PM
Ok, here was the thread. It's called bunker busters, the thread started on post 262, my hyper link doesn't work on my iPad
http://cr4.globalspec.com/thread/80902?Pg=2
Good Answers: 179
11/22/2012 7:35 AM
I'm in HOG heaven!
An A-10A Thunderbolt II (aka Warthog) from the Maryland ANG!!!
Buy an A-10 driver a beer, kill a terrorist! It's incentive!!! LOL thank you very much!
11/27/2012 10:29 AM
When the powder burns doesn't it provide equal force in both directions?
11/21/2012 10:52 AM
One of my buddies that saw the article went in a different direction. As a sci-fi enthusiast, he asked me if I thought some sort of high powered "photon laser" would be able to create propulsion. It's true that photons have momentum, but just how much energy do you think would have to be dissipated to create lift, or would there be no lift at all and just a massive hole in the ground?
[use your imagination]
11/22/2012 5:08 AM
The first need is to analyze and find out which machine guns have the strongest recoil. Strange as it may sound, some machine guns recoil "forwards", the old British .303 Bren for example.....
I found a reference to this strange turn of events here:-
Brengun.htm
Under the heading of:-
Firing the Bren
The sights on the Bren were offset to the left, giving the advantage to right-handed firers; the recoil of the weapon tended to pull the weapon forward, when firing on automatic it would "walk" away from the firer. Some Bren gunners found that a bulleted cartridge driven through a hole in the bipod could temporarily keep the Bren in place.
I once saw a 10 year old, trying out a Bren on an RN open day, get pulled up a small slope!!! (Yes we let kids fire weapons then!!)
Therefore, the design of the gun derives the direction of recoil, so I have to assume that it is possible to not only pick the direction of recoil with a suitable design, but also possible that some machine guns will have no effective recoil, just vibration........Not much use for taking off!!!!
Savage recoil, which is what is needed here, is not fun to shoot with though, even though it might help you to "take off "........
Thought for the day, " Is recoil the right word for a gun that 'recoils' forwards?" Perhaps "For-coil?"
Another thought, I wonder if the LMG, which was a later version of the Bren using NATO ammunition, had the same effects with the recoil......
Even more thoughts, the Bren was such an accurate weapon, the target that you could see and fire at, was marked very darkly and lightly offset from the lightly marked target where the hits were actually scored. The difference was the same as the distance between the gun barrel and the off set sights.........This accuracy was considered to be a hindrance in some actions, as bullets were not "scattered about" enough for some people.
I reckon that with a short 5 or 6 bullet burst, I could kill a terrorist/hit a target accurately at up to 1.5 miles distance........never got to actually kill a terrorist though.....
11/22/2012 6:30 AM
This is a bad idea on so many levels!
Good Answers: 179
11/22/2012 7:40 AM
How in the hell would you aim AK's strapped to a jetpack? You can't, effectively that is. Having fired many an AK of all types at the ranges, it would be virtually impossible to get good solid kills.
AK's, especially AK-47 and AK-74, have one of the lousiest iron sights on a military assault rifle known to mankind! Damn sights are too close together.....it's basically 'spray and pray"!
Good Answers: 114
11/22/2012 1:09 PM
To take a counterintuitive look, I have not fired an AK so I don't know if there is a kickback. I fired a Bren Gun when in the army, and that tried to walk away from the shooter. I also fired a 303 and that sucker did kick back but it is a rifle and not suitable for the rapid fire.
11/22/2012 3:17 PM
On the point of gun safety, an Australian General was interviewed in the USA I believe:-
For those that don't know him, Major General Peter Cosgrove is an Australian.
General Cosgrove was interviewed on the radio recently.
Read his reply to the lady who interviewed him concerning guns and children.
Regardless of how you feel about gun laws you have to love this! This is one of the best comeback lines of all time.
In a portion of an ABC radio interview between a female broadcaster and General Cosgrove who was about to sponsor a Boy Scout Troop visiting his military Headquarters.
FEMALE INTERVIEWER:
So, General Cosgrove, what things are you going to teach these young boys when they visit your base?
GENERAL COSGROVE:
We're going to teach them climbing, canoeing, archery and shooting.
FEMALE INTERVIEWER:
Shooting! That's a bit irresponsible, isn't it?
GENERAL COSGROVE:
I don't see why, they'll be properly supervised on the rifle range.
FEMALE INTERVIEWER:
Don't you admit that this is a terribly dangerous activity to be teaching children?
GENERAL COSGROVE:
I don't see how. We will be teaching them proper rifle discipline before they even touch a firearm.
FEMALE INTERVIEWER:
But you're equipping them to become violent killers.
GENERAL COSGROVE:
Well, Ma'am, you're equipped to be a prostitute, but you're not one, are you?
The radio went silent for 46 seconds and when it returned, this interview was over.
Good Answers: 918
11/27/2012 8:31 AM
Does WikiLeaks happen to have that 46 seconds by any chance? :)
11/27/2012 7:52 AM
Physics is a branch of science simple as that.
11/27/2012 7:57 AM
It's interesting to see possibilities using physics (as unrealistic / unpractical as the scenerios are).
11/27/2012 8:50 AM
This character comes to mind
Good Answers: 21
11/27/2012 10:42 PM
Ground support personnel hard to replace after 1st flight.
Register to Reply 50 comments
Andy Germany (3); Anonymous Hero (3); ben11c (1); BruceFlorida (1); CaptMoosie (2); Doorman (2); fixitorelse (1); Janissaries (4); lyn (2); Mizuti (8); passingtongreen (1); phoenix911 (12); redfred (3); Rixter (1); truth is not a compromise (3); user-deleted-1105 (3)
