Previous in Forum: Which Stepper Motor Configuration to Choose?   Next in Forum: Properties of Alloy Zinc
11 comments
Heat Exchanger Design for Shell and Tube Type H.E.
12/05/2012 10:03 PM
I have a project of installing a centralized Heat Exchanger for 7 engines in a Power Barge to reduced maintenance cost and better cooling system of engines. What are the basic design formulas to start with?
Re: Heat Exchanger Design for Shell and Tube Type H.E.
12/05/2012 10:28 PM
Q = K A (LMTD).
12/05/2012 10:33 PM
I would be wary of a single heat exchanger. Whenever it needs cleaning or repair, all 7 engines will be down.
12/06/2012 12:23 AM
I will make it as centralized HE and distributed to individual engine with isolation valve
12/06/2012 2:45 AM
Alas, that will not help.
12/06/2012 4:43 AM
That's just plain daft.
12/07/2012 1:05 AM
That is fine as far as engines are concerned. How about the exchanger? What Tornado concern is, "if the (single) exchanger fails/under delivers and end up in shutdown, you need to stop all the engines.
Hence the general suggestion would be to have 'stand-by'. If cost is the constrain, I rather suggest to have two exchangers, each to cater 4 engines and get the pipe lines inter connected. If one exchanger fails, the other would permit to run 4 engines at least, or even 5 or 6 engines with a bit of over load on the exchaner or under load on engines
12/06/2012 7:09 AM
if we do all the math and inclue drawings do we get a cut of your check on Friday?
12/06/2012 8:46 AM
Would that increase the maintenance cost?
12/06/2012 11:14 PM
1. Start with energy balance. There are three basic equaztions:
Q = U A LMTDc
Q = WC (T1 - T2)
Q = mc (t2 - t1)
2. Determine LMTDc and U from individual heat transfer coefficient and fouling factor.
3. Calculate A, the surface area required.
4. Determine the final configuration
12/07/2012 4:01 AM
Dear Mr. ARNULFO PALACIO,
First Decide the quantum of Heat to be recovered and the use the BASIC EQUATION, HEAT LOST from the Medium where heat is to be recovered = HEAT GAINED by the Medium to be heated In the HEAT EXCHANGER and use the Equation W x(Tin-Tout)xSp.Heat = U x A x LMTD. Pl. refer Hand Book on Heat Transfer.
While deciding the factors, fluid velocity, fouling factor etc. to be duly accounted, and perhaps additional HEAT TRANSFER AREA to the EXTENT of 10% be provided.
DHAYANANDHAN.S
12/25/2012 2:56 PM
THANKS MR. DHAYANANDHAN.S. THIS WILL BE A GREAT HELP FOR ME SINCE THIS IS MY FIRST DESIGN WORK IN MECHANICAL DESCIPLINE. I AM AN ELECTRICAL ENGINEER AND HAVE BEEN INVOLVE ALSO ON ELECTRICAL DESIGN WORK.
BEST REGARDS
ARNULFO PALACIO
Register to Reply 11 comments
ARNULFO PALACIO (2); dhayanandhan (1); Fredski (1); PWSlack (2); sabriahmad (1); Tornado (3); yesyen (1)
