Previous in Forum: Question on Piping Designengineer   Next in Forum: 10 kW Sailboat Generator
10 comments
Heat Exchanger
12/06/2012 11:55 PM
The Heat Exchanger that use Methanol in Hot Side and Water in Cold Side is use on what purpose?
Re: Heat Exchanger
12/06/2012 11:59 PM
To transfer heat from the hot side to................never mind.
Re: Heat Exchanger
12/07/2012 12:13 AM
I knew that!! transfer from hot to cold...i mean using that media (methanol & water) are usually use for what application ma'm....!!!! Yeah!!! Neva mind!!
Good Answers: 137
Re: Heat Exchanger
12/07/2012 4:42 AM
Come on, if you ask a question like that you should be surprised Lyn's sarcasm was as restrained as it was!
Re: Heat Exchanger
12/07/2012 3:17 AM
Cooling the methanol and heating the water simultaneously is one possibility, though it's a bit difficult to see from here.
Re: Heat Exchanger
12/07/2012 3:48 AM
What type of media? i mean, is it liquid or vapor?
Re: Heat Exchanger
12/07/2012 4:15 AM
Nope. It's still too difficult to see the process from here. Maybe a P&ID and a local Process Engineer can help, perhaps?
Re: Heat Exchanger
12/07/2012 9:20 AM
Open wide. Here's your first feeding.↓
table of contents - The University of Tennessee at Chattanooga
Getting Started - Aspen Shell & Tube Exchanger
This took 30 seconds. Have you done ANY research yet? If yes, where? If no, why not?
Re: Heat Exchanger
12/07/2012 10:15 AM
Condensation, principally, as in a still. Welcome to the backwoods, buddy.
Good Answers: 92
Re: Heat Exchanger
12/07/2012 3:27 PM
Not nearly as interesting a purpose as the Heat exchanger that uses Ethanol in Hot Side & Water in Cold Side!
Seriously, it's whatever it was spec'd for, & from here we can't tell if it's a condenser or a plate type unit or....
Re: Heat Exchanger
12/08/2012 6:07 PM
For further information in a practical use, watch the TV program "Moonshiners".
Codemaster (1); JNB (1); lyn (2); nudad0308 (2); PWSlack (2); Tornado (1); walt (1)
