Previous in Forum: Grading Ring for Insulators   Next in Forum: Earthing Question
Generator Electrical Problem
12/10/2012 1:49 AM
i have 200 kva generator ...that engine having the electrical problem ..that engine was started on mechanically .. but not starting via panel board ,,,, please suggest what cause i want to check ??????
Re: Generator electrical problem
12/10/2012 3:29 AM
Read the manual.
12/10/2012 4:29 AM
One of the possibilities is that there was no power with which the panel could operate. There are others, and they cannot be seen from here.
Re: Generator Electrical Problem
12/10/2012 9:55 AM
check the terminal connections...and all electrical circuit referring its diagram.
"No matter how hard the past,you can always begin again."
12/10/2012 1:43 PM
Check the control panel, that seems like the most likely location of the problem (component failure, protective device operating, components need a clean, etc).
Good Answers: 19
12/11/2012 11:29 PM
If it is cummins engine there is a solenoid operated valve in the pump. This opens up during starting. Operates on 24 volts supply from battery. If there is any fault like low lub oil pressure or high engine water temperature or over speed. The supply to the solenoid will be cut off and engine will not run You have to check the wiring and the sensors. May be sensors would have operated .
Ramesh,Freelance Electrical/automation Consultant
jack of all trades (1); PWSlack (2); ramvinod (1); vir540 (1)
