Previous in Forum: Repeated Cable Failures in 34.5 kV Cables   Next in Forum: Internal Arc Classification of High voltage Metal Enclosed Switchgear
Calculate the Radius of Cable Tray
12/11/2012 8:44 AM
Hi All
any help i need some detail on how to calculate the radius of cable tray.
Regard
Mohd
Re: elbow
12/11/2012 8:48 AM
Starting from where?
Good Answers: 34
Re: Calculate the Radius of Cable Tray
12/11/2012 9:17 AM
Links below will provide you, some solutions to your question.
Calculating the Radius of Cable Tray
Good Answers: 15
12/12/2012 9:21 AM
You give no detail of the type and size of cable you want to put onto this tray. Cable manufacturers will give you the minimum bending radi for cables. Usually on a large armoured cable it is about 8 times the overall cable diameter.
It is good practice and often obligatory to ensure some services are seperated - 11kV cable from a data cable.
Consider the loading on the tray - how many deep th cables are going to be laid.
You should now have the makings of working out your minimum radius.
There are other things to take into account - load, deflection, grouping, EMC etc.
Joshi (1); PWSlack (1); silverfox (1)
