Previous in Forum: PCB Sterilization   Next in Forum: Calculation of Rp and Icorr Based on Cycle Usage
10 comments
Water Boots for Steam Lines
12/26/2012 11:06 AM
i don't know the meaning and of "water boots for steam lines" , i am looking forward to a help that may be offered by someone familiar with this term. thanks in advance
Re: water boots for steam lines
12/26/2012 12:05 PM
It would help if you gave us some context. Steam is used in many processes. You could even have a typographic error that should read boats or booth for boots. It might even be stream or seam line. It is also impossible to help when you only tell us what you do not understand.
Can you tell me what I'm thinking? How about now?
Re: Water Boots for Steam Lines
12/26/2012 3:11 PM
It is a short downward branch off a steam line that collects condensate that may have formed. The liquid water can be drained off by a steam trap or condensate drain, preventing it from being carried further along the steam line.
12/26/2012 8:15 PM
thanks. i think your interpretation is closer to the right answer and i am looking for and i almost got it, i think the "water boots for steam line " just like steam header drips. am i correct?
12/26/2012 8:17 PM
That sounds like the same idea; just different language that would be used around the world.
You may be able to compare the wording of specifications with details shown on drawings. That might help to clarify.
12/26/2012 8:23 PM
good idea, but the problem is i dont have the drawings and this is the first time i encounter such term. anyway, your comments have clarified all my doubts, thanks.
Good Answers: 445
12/26/2012 3:12 PM
Assuming that you are in a process plant where the steam is contanimated and/or water is scarce, then the term "boot" is used interchangeably with "sump"; i.e., a device to collect the condensate released from steam-traps and/or valve stem leakage to prevent its loss or release to the environment.
12/26/2012 8:17 PM
thanks, your comments illustrate further.
Good Answers: 61
12/31/2012 9:36 AM
hu dan,
go here and you will see two versions of a "Boot" for a Steam Line complete with suggested dimensions.
http://www.red-bag.com/jcms/design-standards/229-bn-ds-c44-condensate-pots-for-main-steam-lines.html
I hope this helps,
Do it once and do it right
01/04/2013 9:41 AM
thanks, Mr. PennPiper. Your recommended drawings give me quite direct understanding about the concept of water boots, just the same facilities like condensate collection pot.
01/09/2013 7:20 AM
Thanks for the information.
fastokfasteners.com
Register to Reply 10 comments
dealer88 (1); hu dan (4); PennPiper (1); RAMConsult (1); redfred (1); Tornado (2)
