Previous in Forum: Water Supply Design Problem   Next in Forum: Rating Selection Criterion of GT, UAT and ST
Lights Flickering
12/27/2012 11:01 AM
There is a common source where we can get either eB/DG source when the DG source is there will not be any flickering of the lamps but when the EB source is there will be a Fluckering kindly tell us any reason for this
Re: Lights flickering
12/27/2012 11:31 AM
You seem to have lots of electrical problems at your facility.
You should hire an engineer to resolve these problems for you.
Re: Lights Flickering
12/27/2012 5:20 PM
Really and truly...it's your switching frequency from your crappy power source. Lights on-lights off-lights on-lights off, many times per second/minute. This happens at such a frequency that you can visually perceived the "flicker"
You could try adjusting your visual perception by blinking in sync with the peak-to-peak voltage...but I tried that myself and got a headache really fast. I don't recommend it.
I'm going to go out on a limb here and guess that you have...hmmm...fluroescent lighting....did I get that right? I did...? Wow, that was lucky. You can reverse-engineer your problem by learning a little about fluorescent lamps. <--That's a link!
Check your voltage with a quality oscope, RMS meter, and/or a power quality meter. It will become pretty obvious when you see your power's trace on the screen.
common knowledge...less common than common sense
12/27/2012 10:32 PM
Dear kuppahalli,
It appears, there is a problem in the NEUTRAL LINKING on the EB POWER SUPPLY SYSTEM is connected which causes the fluctuation.
Pl. check this Neutral Connection whether it is proper. I have experienced a similar situation and after rectifying the Neutral connection, which was loose and sparking, the problem was solved.
DHAYANANDHAN.S
12/27/2012 11:10 PM
Do you have an electric arc furnace, fabrication shop with electric arc welding in the viscinity?
Good Answers: 34
12/27/2012 11:29 PM
Is he capable of following the drift, when what he wants is spoon feeding!
Good Answers: 804
12/29/2012 9:58 AM
"...there will be a Fluckering..."
LOL
01/02/2013 7:27 AM
Under what circumstances does the non-flickering turn into a Fluckering?
Register to Reply 7 comments
debata07 (1); dhayanandhan (1); Joshi (1); JRaef (1); lyn (1); PWSlack (1); The.Tinkerer (1)
