I have a client who has a 2001 Ford Focus 2.0L 4 cylinder that just dropped another valve seat (this time #4). Less than 5000 miles ago, the #2 cylinder dropped the intake valve seat. The valve seat is made from a powdered metal and is very brittle. When the valve seat drops, the valve makes contact and the valve seat breaks apart.
The mechanic sent the cylinder head to the machine shop, where they replaced the #2 intake valve seat, but not the others. The new valve seat is made from a hardened steel and is both deeper and has a wider outside diameter, which makes it less sensitive to falling out. Even if it drops a little, the valve can hit it and hopefully not break the seat - and of course pull it back in place.
Since the #4 valve seat dropped so soon after the last valve job, my client is upset. The mechanic is blaming the machine shop for not replacing all the intake valve seats. The machine shop specializes in head rebuilding and should have known that these engines are notorious for dropping valve seats - the engine rebuilder should subscribe to AERA. The machine shop claims that the mechanic didn't ask for all to be replaced, so he only replaced the #2 intake seat. My client is very upset, because the cost is in the $1,500 range - this time they will replace the remaining three seats.
I have three questions that I have not been able to find answers to (one is an opinion):
1. Who do you think is responsible? Should the mechanic charge for his labor for the second valve seat repair? How about for the parts that need to be replaced again (head gasket, seals, etc)?
2. Why is the problem only on the intake valve seat? Since much of the problem lies in the different expansion rates of aluminum (head material) and the steel (valve seat). The theory goes like this - as the engine warms up, the aluminum and steel grow at different rates and when the engine gets too hot, the difference is great enough to allow the pressed in seat to drop. So if this is true, why doesn't the exhaust seat have more problems (exhaust side of the engine must be a higher temperature than the intake)?
3. Based on my research, the most likely valve seat to drop is the #4 cylinder. I would think that the middle cylinders would be more prone, since the outside cylinders would have better cooling. So what makes the #4 cylinder the weak link?
You're help is greatly appreciated.
