Previous in Forum: What Are the Barriers to Building Thorium Plants?   Next in Forum: Durable and UV Resistant Coating for Non-Metal Surface
APIX Pilot Plant Design Project - Member - New Member
Weight Reducing Structural System for Panels
01/13/2013 11:57 PM
We are developing a structural system for Panels ... and would need to look at weight reduction possibilities, commensurate with optimized Cost. The illustration below shows the overall design:
We would appreciate experienced advice from Members so that we could look at Optimizing our Design and Materials selection. The load bearing need could be on the basis of 10 Kg/sq cm (uniform load) on the surfaces The Discussion may look at the following:
1. The Material/ Material-system for the "Skins"
2. The Adhesive for the system
3. The Core
4. Optimization of Costs
Our values have to be measured by what we could offer to the society and to the world, when a "balance sheet" is drawn up at the time we leave our "foot prints on the sands of time".
Re: Weight Reducing Structural System for Panels
01/14/2013 12:13 AM
How are the panels to be supported in order to handle the given load (≈142 psi)?
01/14/2013 12:19 AM
Hi Tornado
The Four regions that surround the inner Core would have "stiffening" strips. Most of our applications would have a "cantilever" arrangement, whereby the panels would be the cantilevered Load bearing platform. 10 Kg/sq cm = approx 145 psi. Hope this explanation helps you. thanks again
Good Answers: 110
01/14/2013 2:22 AM
There is far more to composite sandwich panel design and construction than can be covered in a post or two.
A very good yet very brief text that can get you started on the basics is this one by Hexcel:
http://www.hexcel.com/Resources/DataSheets/Brochure-Data-Sheets/Honeycomb_Sandwich_Design_Technology.pdf
Don't be thrown off by the "honeycomb" in the title. Any core material will have specified values for compressive strength and stiffness, shear strength and stiffness, etc, etc, etc. (So plastic foams can replace honeycomb as a core in many panels with some sacrifice in weight but a reduction in cost.) Honeycombs are a little more challenging to bond to skins, because the bond area is very small and because care must be taken to avoid filling the cells with excess adhesive. With foam cores, it is often possible to laminate the cores and skins all at once, using the laminating resin as the adhesive between core and skin. (However, in very light panels the amount of resin that fills the surface can be an issue that must be controlled, even with foams.)
If you look around the world of cored panels, you will see skins of aluminum (and other metals), wood, solid plastics, fiber-reinforced plastics (with 6 or 8 common fiber types and 4 or 5 common resin classes) and various (typically resin infused) paper products. Cores can be numerous types of foams, kraft paper honeycomb, aluminum honeycomb, aramid honeycombs, etc., all available in a wide range of material properties (including stiffness and strength in various directions, corrosion resistance water intrusion resistance, fire resistance, electrical resistance, etc).
The fundamental design principle of a cored panel is that of the I beam: under load, one skin is in tension, the other in compression, and the core is in shear. But in practice, the core will be subjected to high point loadings (compressive) that can destroy the structure if not correctly planned for. You need to understand exactly how the panel will function as a beam early in the design process. Given a particular beam loading, then an optimized panel will have a particular total thicknesses and ratio of core thickness to skin thickness, depending upon the properties of the materials used.
All that can be said at this point regarding your application is that the core material must have a compressive strength of greater than 100N/cm2 at very least. But it is a very rare sandwich panel that need only resist a compressive load normal to its surface. There is usually a reason that a sandwich panel is chosen over a simpler construction, such as its stiffness in bending. If you are using a sandwich to resist bending, then the first thing is to find out is the magnitude of the bending load. That will, of course, vary dramatically with the spacing of supports.
The Hexcel document will get you started at looking at the basic design issues. At its end, it provides a couple further references.
Think big. Drive small.
01/14/2013 3:25 AM
Hi K_Fry ... Thank you for your good advise and suggestions. The website of http://www.hexcel.com ... presents many details (as pointed out by you) and I am studying those.
Thanks again ...
pvhramani
01/14/2013 9:29 AM
You might investigate what others are already doing.
This sounds like a Mapes Panel. These panels are (usually) used as infill for aluminum window walls, where glass is undesireable.
Doorman (1); K_Fry (1); pvhramani (2); Tornado (1)
