Previous in Forum: Making Electric Motor Brushes   Next in Forum: Single Phase To Ground Fault In Star-Star Transformer
11 comments
Difference Between Fuse & Detector
01/15/2013 9:44 PM
difference between Fuse & detector
Re: difference between Fuse & detector
01/15/2013 9:46 PM
Page 34, Elementary Electrical Terms, Vol II.
01/15/2013 9:49 PM
With your abysmal level of knowledge, you have no business using a name like "Instrument365".
01/16/2013 1:48 AM
i made mistake i had wrote difference between fuse and contactor
01/16/2013 4:01 AM
That was answered here!
01/16/2013 9:28 AM
Well I can clearly see that English syntax and grammar is not your strong suit. I guess that is why you do not understand how to use a dictionary or search engine for what, at first, seems to be a ridiculously trivial question. To try and answer your question I must make a few assumptions due to the imprecision of your text.
What a fuse and contactor have in common in electrical engineering is that they both interrupt current flow. The difference is when they interrupt this current. A contactor does this under normal operating conditions and as such is expected to do this many times because the current magnitude will be understood. A fuse interrupts current under a fault condition and therefore the current interrupted will be unknown. Since a failure operating condition produces an unknown current condition, a fuse is designed to produce a controlled failure in itself. This prevents a more catastrophic failure in something else that may start a fire, explosion or a variety of other dangerous conditions.
01/16/2013 9:42 AM
Go easy with Instrument365. Remember an instrument is just a tool. A tool without the mind behind the tool is just a relic artifact for archaeologists to wonder about.
01/15/2013 10:06 PM
In some cases they are combined....
01/15/2013 10:29 PM
Fuse is written with Capital letter and detector not.
That means a Fuse is important and a detector is only used when the Fuse has blown!
01/15/2013 10:58 PM
Yes, there is a difference between "fuse" and "detector". Since "detector" is only a noun, the indefinite article "a" is always implied when it is missing. However, "fuse" can be a verb or a noun. So without the indefinite article "fuse" is a verb. Unless your capitalization means you are asking about Mr. Bill meeting Mr. Fuse.
01/16/2013 2:59 AM
Some Private Eye Detectors are rather shady characters and one should be careful when dealing with them.
Thorium Reactors, not just for Breakfast anymore.
01/16/2013 3:15 AM
...can be determined by entering these words into a search engine, or looking up the articles on these topics in an on-line encyclopaedia, such as Wikipedia, thereby shortening the time between asking the question and obtaining an answer.
Register to Reply 11 comments
garciayvegas (1); IdeaSmith (2); Instrument365 (1); lyn (1); PWSlack (1); redfred (3); SolarEagle (1); Tornado (1)
