Previous in Forum: How to Wire an 8 Pin Ice Cube Relay with a Motor Starter?   Next in Forum: Pfaff S/M Blown Switich Board
XLPE Cable
01/27/2013 12:41 AM
Dear all
we have 132kv xlpe cable in sub station this cable installed in trench 1m depth x 1m width x 1m hight and cover with Concrete the question is We noticed the water enter to trench .are this effect on cable
Regards
Pathfinder Tags: xlpe cable
Engineering Fields - Electrical Engineering - Hentoyk Philippines - Member - BRUTUS Saudi Arabia - Member - Brutus United Arab Emirates - Member - Brutus
Re: xlpe cable
01/27/2013 3:04 AM
The cable is safe as long as the outer cable insulation is intact and without damage or crack to where the water can penetrate into the cable. Though water can enhance degradation of cables but does not cause direct breakdown of the XLPE or EPR insulation, but rather reduces the dielectric strength of the insulation, eventually weakening the material to the point where it is susceptible to voltage surges that can initiate partial discharging. Partial discharging causes relatively rapid electrical degradation, leading to an electric tree and a faulted condition in weeks to months. Instantaneous failure in the weakened condition would only be expected under severe current surge conditions.
If there is a will... there is a way... No pain / No gain.
Good Answers: 181
Re: xlpe cable
01/27/2013 6:44 AM
If you can isolate the cable ends from earth you can test the integrity of the sheath with a simple IR test. It's only way to allay you're fears.
Re: xlpe cable
01/27/2013 8:19 AM
Dear Mr.FADHEL,
The anser for your Question is NO. Mere water entry will not cause damage, provided the outer sheath is intact.
DAYANANDHAN.S
Register to Reply 3 comments
dhayanandhan (1); hentoyk (1); TonyS (1)
