Previous in Forum: Inductive Kick from Transformers   Next in Forum: Question on Generator Capacity Curve
Question Regarding Fault Current
01/31/2013 3:53 AM
What are the consequences for the fault current in 11 kv distribution if two transformer 66Kv/11Kv , 40Mva are running in parallel ?
Also any remedies to reduce fault current.
Regards,
sunil
Re: Regarding fault current
01/31/2013 4:04 AM
Fault current stops when circuit protective devices operate.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
01/31/2013 5:16 AM
Is this in the right place? Shouldn't in be in the Electrical Forum?
Chaos always wins because it's better organised.
Re: Question Regarding Fault Current
01/31/2013 1:56 PM
Unpleasant, expensive and potentially jail-worthy.
I find a fuse or circuit breaker helps to limit fault current, backed up by a degree in engineering specialising in industrial transmission and distribution and selected after performing a fault current analysis of the system in question.
Seriously thou, this is a theoretical or homework question right?
Good Answers: 15
02/01/2013 9:05 AM
Is the distribution system sized to withstand a fault with both transformers connected.
If the board isn't large enough to withstand the fault then you can make sure both transformers are not locked in at the same time with a set of Castell or similar locks.
The fault can be limited by fuses or a reactor.
You are asking a big question with very little information.
02/05/2013 8:57 AM
3 phase fault current or earth fault current ???
02/05/2013 9:04 AM
earth fault current or 3phase fault current ??
Register to Reply 6 comments
Anonymous Poster (2); English Rose (1); jack of all trades (1); PWSlack (1); silverfox (1)
