Previous in Forum: Daniel 1500 Series Turbine Flow Meter   Next in Forum: Elevation of Instrument
ARTEC AM12E Plus Flatbed Scanner Power Adaptor
02/01/2013 5:34 AM
hi everyone.
I have an Artec AM12E Plus scanner for which I don't have the power adaptor.
Can anyone tell me what kind of power adaptor I need, i.e Voltage and Current
Thanks
Re: ARTEC AM12E PLUS FLATBED SCANNER POWER ADAPTOR
02/01/2013 5:38 AM
Re: ARTEC AM12E Plus Flatbed Scanner Power Adaptor
02/01/2013 7:03 AM
Contact this guy, he has one for sale with the adapter, maybe he will tell you what adapter specs are.
http://www.donedeal.ie/for-sale/computeraccessories/4418443
If not, it's time to upgrade, this is an old scanner, parallel port, maybe time to go to USB.
02/01/2013 8:14 AM
Hosa Technology A...$13.95B&H Photo-Vi...Aluratek ANPA01F Un...$42.99Newegg.c...AluratekUniversal Po...$38.42WalmartUniversal120W DC Po...$25.00BestBatt.comLenmar® LAC50 50W...$39.99RadioShackShop by price:Up to $20 $20 - $35 $35 - $50 Over $50
Click on the boxes for pictures and details.
02/01/2013 8:48 AM
DC adapter 6-9 volts.... I need the current draw from the electrical plate on the scanner....
02/01/2013 10:37 PM
Most of these devices have a voltage regulator and a fuse inside them. The fuse will give you the maximum current draw and the regulator number will give you the regulated voltage to the circuitry, allow 30-50% over that and you should be OK.
If it also incorporates a rectifier bridge then the power pack will likely be AC and you would allow for the voltage in to be a bit higher by a volt or so.
bwilko (1); JPool (1); lyn (1); PWSlack (1); SolarEagle (1)
