Previous in Forum: Direct Online Starter   Next in Forum: Take off Materials Vs Bill of Materials
15 comments
Second Order Differential Equations
02/01/2013 7:49 AM
hi all, this is my first post so please bear with me - any advice/support would be warmly welcome. I have been doing some work on a simple RLC electronic circuit whose transfer function follows the standard second order transfer function.
The forcing function (input) is a periodic square wave function and I am trying to write an equation for the output - time based.
Please find 2 documents attached in which I have tried to develop equations for the output using 2 different methods. The first one is using complementary function and particular integral (which I do not like). The second one uses Laplace transforms. I have found a time based equation but when i input times i do not think i am getting the correct output values. Can someone please have a look- particulaly the Laplace.pdf.
Many thanks, derek
CR4 Admin - email address removed
Posting an email address is against the CR4 site rules.
Pathfinder Tags: laplace
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
Re: second order differential equations
02/01/2013 8:03 AM
I do not see any attachments as are referenced. Did I hit my head too hard this morning? I didn't think posting attachments was possible ...
So instead, I will post this link to wikipedia! http://en.wikipedia.org/wiki/Laplace_transform
02/01/2013 8:47 AM
thank you for the warm welcome - I hope you did not hurt yourself getting up this morning.
another (Guru) user seems to think files can be uploaded !!!!
Yes I have already visited the wikipedia and other relevant sites - but still no joy.
I will try the Fourier method now.
Good Answers: 110
02/01/2013 1:25 PM
You can copy a portion of a pdf into a graphic file using a screen capture
This requires some fiddling to make it readable... and if it goes on for pages, it is doubly problematic. You can also drop the file in something like dropbox, and provide a link.
Think big. Drive small.
02/02/2013 4:48 AM
thank you for you suggestion.
the pdf is 8/9 pages, so could be a bit awkward taking screen shots etc.
Even though i havent done it before i will try uploading the pdf to a host site with a link.
cheers, derek
Re: Second Order Differential Equations
02/01/2013 8:26 AM
You can post your attachments as picture file by clicking on little green camera icon and selecting file...Let's see if you can master this before moving on to more complex issues...welcome to the forum
02/01/2013 8:41 AM
thank you for the warm welcome.
I had tried as you had suggested, but got a message that the server would now accept MIME ???
Looks like i cannot do this simple ask and perhaps should give up on ode !!!
02/01/2013 8:52 AM
Multipurpose Internet Mail Extensions (MIME) is an Internet standard that extends the format of email to support:
  • Text in character sets other than ASCII
  • Non-text attachments
  • Message bodies with multiple parts
  • Header information in non-ASCII character sets
02/01/2013 9:38 AM
Eagle, a MIME is a terrible thing to waste.
02/01/2013 2:47 PM
Yup...
02/01/2013 11:01 PM
first of all you cannot tell about the actual equation, by the way it can solve by Laplace transform also web.firat.edu.tr/agulucar/AM/laplaceforengineer.pdf
ee.saurav@yahoo.com
02/02/2013 4:52 AM
thank you i will have a look
02/01/2013 11:04 PM
In order to use a square wave to excite a system, I have always used just one edge to limit it to a step function. Then I differentiate that to get an impulse, and the differentiated output is then the impulse response. Of course, the FFT of the impulse response is easy to calculate. To normalize, divide the output FFT by the input FFT to get the corrected FFT, and that will be the Frequency Response Function (FRF). The transfer function is then the LaPlace Transform of the FRF.
Care must be taken to assure that the edge rate of the square wave is fast enough to excite all modes of the system under test. Also, the duration of the step must be long enough to allow all modes to damp to zero. This usually means that the square wave is a relatively low frequency (i.e. a low repetition rate).
02/02/2013 5:02 AM
thank you for getting back.
i would really like to upload the laplace pdf for comment because i think i am almost there with it and i am only missing/overlooking something minor.
i will bear you solution in mind if i cannot solve with the laplace transform.
thanks, derek
Good Answers: 59
02/01/2013 11:22 PM
There is more than one way to skin a cat. I prefer to use the Bode plot. The first order plot is standard in renormalized frequencies. For second order you add two plots together. Phase response is standard per section. You read out every harmonic out, amplitude and phase delay for each.
I know, it is not standard here. But I like the graphic method's directness.
02/02/2013 5:06 AM
like before i would like to progress the laplace method although i have plotted the bode plot of the freq. response and also the step response function and considered damping.
thanks derek
Register to Reply 15 comments
derick007 (6); ee.saurav (1); JCase (2); K_Fry (1); leveles (1); SolarEagle (3); WoodwardDL (1)
