Previous in Forum: Ice Formation On a Cryogenic Service Line   Next in Forum: Minimum Allowable Wall Thickness for Vessel
How to Calculate the Volume of Oil at Required Temperature
02/04/2013 8:25 AM
Dear All,
My client has given me Mass flow rate of Furnace Oil. For calulation Pipe sizing i converted it to Volume Flow rate by following method.
Density @ 15 Deg = 950 Kg/cm3
Total Flow = 39000 Kg/hr
Volume FLow = 39000/950 = 41.05 m3/hr @ 15 Deg
P1 V1/T1 = P2V2/T2
41.05/(273+15 Deg) = V2 / (273 + 115 Deg) (115 required temperature and pressure constant)
V2 = 44 m3/hr
Please advise me whether i have done correct or not.
My doubt is whether the gas law formula can be applied for Oils also??
Please clarify my doubt.
Regards
Rakesh Reddy
Re: How to Calculate the Volume of Oil at Required Temperature
02/04/2013 9:23 AM
Maybe, maybe not, though it still comes out at 80mm pipe, whichever value is chosen.
02/05/2013 5:51 AM
The gas law does not apply.
Good Answers: 183
02/05/2013 9:13 AM
If you make the effort to look at any book about oils you find a volumetric expansion coefficient which allows to correctly compute what you want. I have a secondary question : are you aware of the specific weight you mention ? It is 1 million times heavier than usual oils ! You should have written m^3 not cm^3!
The low for gases -as was already mentioned- applies for GASES not for liquids!
Register to Reply 3 comments
nick name (1); PWSlack (1); Tornado (1)
