Previous in Forum: Effective Electrical Resistance   Next in Forum: Why Diversity Factor?
10 comments
3 VDC Motor
02/10/2013 10:42 AM
I have a 3 vdc motor that draws less than 0.5 amps. What size pot would I need to vary the voltage from 0 to 3 vdc for speed control ?
Re: 3 VDC Motor
02/10/2013 11:56 AM
Good Answers: 445
Re: 3 VDC Motor
02/10/2013 12:32 PM
Power= Volt x Amp, 3V x 0.5A= 1.5 Watts, use the sites above and get a wire wound potentiometer rated at 2 Watts or more, I'll leave the resistance range as an exercise for you.
Re: 3 VDC Motor
02/10/2013 1:04 PM
what sites above ?
Re: 3 VDC Motor
02/10/2013 1:51 PM
As Sherlock might say, this is a 3-roach problem.
Re: 3 VDC Motor
02/10/2013 1:55 PM
He smoked weed?
Re: 3 VDC Motor
02/10/2013 2:32 PM
Opium actually (well, fictionally).
Good Answers: 110
Re: 3 VDC Motor
02/10/2013 4:03 PM
Wow, wouldn't it be cool if eyes were mounted so they could tilt up and down! Maybe a person's head could be mounted in some way that would allow it to tilt too.
Think big. Drive small.
Re: 3 VDC Motor
02/11/2013 2:20 AM
The speed control of DC motors is not done by varying the dc supplied but it is done by using PWM of the supply(3V). This is done as the motor will not have torque at low speeds as well as it will not start to rotate with low voltage.
Gajanan Phadte
Good Answers: 48
Re: 3 VDC Motor
02/11/2013 4:28 PM
The speed control of dc motors is often done by varying the voltage. Whether or not it works depends entirely on the speed range you need (you can get up to 10:1 with voltage control, which is often enough, vs. more than 100:1 with PWM) and the motor loading, and particularly how the load changes with speed. On many applications the required torque at reduced speed drops more than the motor torque at reduced voltage. The OP doesn't state the application, nor the speed range required, so we don't know if PWM is required or not.
Good Answers: 110
Re: 3 VDC Motor
02/12/2013 12:46 AM
In most cases PWM acts as the means through which voltage is varied. Many DC motors (and especially 3 volt motors which are virtually always permanent magnet type) have an rpm/volt constant in recognition of the fact that speed varies with voltage, and torque varies with current.
Varying voltage with a large pot is inefficient, but for the OP's purposes it might work fine.
Register to Reply 10 comments
BOBR (1); gmphadte (1); Holzfeller (1); K_Fry (2); lyn (2); RAMConsult (1); Tornado (2)
