Previous in Forum: Galvanized Cattle Panel in Concrete Slab vs 1/2'' Rebar?   Next in Forum: Concrete Columns
8 comments
Barn Heat
02/16/2013 10:49 AM
I am trying to heat a 30 x 30 room in an insulated barn. I'm using an electric garage furnace and don't know the air flow possibilities. I would like to know which would be better, a 4" or 6" insulated corrigated heating tube on a 25 foot run? I have an 8 x 20 heat opening coming from the furnace duct. Would it be better to do a trunk line for the 25 ft and then have 4 or 6" tubes coming off of that or devise four separate trunk lines of the 4 or 6" tubes, two going 15 ft and two going 25 ft into the room? Basic question, will heated air cool faster in a 4" tube at 25 feet or in a 6" at 25 ft?
Re: Barn Heat
02/16/2013 10:54 AM
Why do you need to heat an insulated barn in Panama?
Re: Barn Heat
02/16/2013 11:34 AM
Maybe to grow "vegetables", they don't like the cool nights......
Good Answers: 25
Re: Barn Heat
02/17/2013 10:57 AM
Or herbs. Or, perhaps, "herb"!
Re: Barn Heat
02/16/2013 11:37 AM
You probably don't need any duct work, and certainly not insulated....If the room is open just shoot the air across the room....
Will the A/H be vertical or horizontal...? Heating only? Mounted in the space?
Re: Barn Heat
02/16/2013 1:29 PM
Its call thermal conductivity. The heating rate would be the same
Re: Barn Heat
02/17/2013 6:22 AM
It would be better to locate the heater in the center of a trunk line, then, the air only has to travel half the distance to the vents,and can be a smaller size,because it only carries half as much air per leg.I would run a 14x14(15 feet) to the center of the room, where it would connect to a 10x14 "TEE" trunk running 15 feet in each direction.
Then put your registers where you please.
IMHO
Re: Barn Heat
02/17/2013 3:35 PM
Thanks, you make sense. By taking the majority of heat go half way thru the room and then have small lines take off from there sounds logical. I appreciate the input.
Good Answers: 19
Re: Barn Heat
02/18/2013 2:27 PM
Why not just install one of these in the barn and have it blow diagional across the space?
http://www.growersupply.com/mod17btuheat.html
Register to Reply 8 comments
Ed Watts (1); HiTekRedNek (1); JPool (1); phoenix911 (1); redfred (1); SolarEagle (1); Stedou73ish (1); troyhib (1)
