Previous in Forum: Isolating Transformer Alternative   Next in Forum: Control Transformer
9 comments
Use Aluminum Wire or Tubular Busbar
02/24/2013 8:16 AM
Dear all
Which is better to use aluminum wire or use tubular busbar if both bear the desired current ? and why?
Re: use aluminum wire or tubular busbar
02/24/2013 9:26 AM
And the "tubular busbar" is made from what material?
02/24/2013 12:10 PM
Dear sir
tubular busbar also aluminum
Regards
02/24/2013 1:25 PM
So then, building on what RAMConsult said about skin effect, which choice would have more, "skin"?
That would be the one I'd use, but I'm not into electricity.
Good Answers: 444
Re: Use Aluminum Wire or Tubular Busbar
02/24/2013 11:22 AM
Google on "Skin Effect" and apply what it says to answer your question.
02/24/2013 1:10 PM
Like all things in life it depends on the application.
For high voltage substations use tubular bus bar.
Jack - We design and build tubular aluminium substation bus bar systems.
02/24/2013 4:14 PM
Dear sir
thank you very much
but we have existing sub station 400kV consist of Four diameters all diameter are
tubular aluminium .one company added new fifth diameter
and made of aluminum wire .please What is the difference between them?
Regards
02/24/2013 4:20 PM
Without seeing the site it is hard to say, but both systems have their advantages and disadvantages depending on the site (cost, flexibility, structural support ease over long distances, wind loading, thermal expansion, connection, life, transport and erection on site, etc).
Tubular is better overall, but not best for all situations. Perhaps cost was the driving factor for the fifth run, or perhaps something on the site made bus bar too difficult to fit.
04/08/2013 4:35 AM
Is there some reason why the company that installed the fifth item cannot be contacted by telephone directly?
Good Answers: 42
02/25/2013 12:15 AM
As was already said, for each application you have to choose the suitable system and material. For voltage above 230 kV, tubular aluminum is preferred due to reduced skin effect and corona losses. See for instance:
Bus Conductor Design and Applications
Usually all substation design group has a software in order to calculate the efforts and choose the switchyard -included short-circuit current dynamical resistance and so on.
Julius
Register to Reply 9 comments
7anoter4 (1); FADHEL (2); jack of all trades (2); lyn (2); PWSlack (1); RAMConsult (1)
