Previous in Forum: Digi Master DC Drive   Next in Forum: Deep Water Submergable Pump Repair
Surge Protective Device
03/02/2013 12:27 AM
Why the electrical designer not giving (type 1 or type 2) surge protective device in the electrical panels?
Pathfinder Tags: surge protective device
Re: Surge protective device
03/02/2013 2:02 AM
Re: Surge Protective Device
03/04/2013 3:27 AM
No joy with the phone call to the electrical designer, then?
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
03/04/2013 8:01 PM
Two Questions.
1) is it the main board from the mains?
2) Did you Specify it in your scope?
If an SPD is not mandatory in your local standard or regulation, it may not be included unless it is specifically requested in your scope.
In general SPDs are located in the incoming Main board from your supplier or on your generator board. Not usually included in sub boards unless specifically requested in your scope.
Regards,
Sapper
It's all about the Boom! - MythBusters
Register to Reply 3 comments
nobodysomebody47 (1); PWSlack (1); Sapper (1)
