Previous in Forum: Pumps   Next in Forum: Slury Immersed Wire Rope Maintenance
9 comments
Engineering Fields - Chemical Engineering - New Member
How Backpressure Is Create By Static Lift
03/06/2013 9:03 AM
The question is quiet clear from the title. Let us suppose in a condensate line (of steam for instance) backpressure is generated because of the vapour pressure of noncondensables...but what is static lift & how it contributes to backpressure. as far as I know static lift is just another name of buoyancy force...
Chemical Engineers are like high Temperatures & high Pressures
Re: How Backpressure Is Create By Static Lift
03/06/2013 9:58 AM
'...The question is quiet clear from the title. Let us suppose in a condensate line (of steam for instance) backpressure is generated because of the vapour pressure of noncondensables...'
No, the question is not 'quite clear' from the title. Unfortunately, what followed in the post made it even less clear.
While it feels good to do a good job writing something clear and concise, skipping right away to congratulating yourself for such clear expression is a bit pompous.
Congratulating yourself for clear expression when that is not actually the case, takes it to a completely different level.
Good Answers: 125
03/06/2013 10:39 PM
Why is this ot ???
I corrected that...
03/06/2013 10:43 AM
Try blowing water up a 3-meter tall tube, and you will see that it requires pressure.
03/06/2013 10:45 AM
The concept is simple. Don't use the steam pressure in the heater to lift the condensate into the return main; use a pump instead.
03/06/2013 4:27 PM
Static can be controlled, or eliminated, by proper grounding.
03/07/2013 2:13 AM
Static pressure represents potential energy due to height of fluid. If Ps is the static pressure (Pascal), then it is related to density and height as below:
Ps = density (kg/m3) x g (m/s) x height (m)
Hope the above explains your concern about static pressure
United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Hobbies - Target Shooting - New Member Safety - ESD - New Member Technical Fields - Education - New Member
03/07/2013 8:37 AM
In my life previous to becoming an engineer, I used terms like "back pressure" only to slowly come to the suspicion that this thing didn't exist. Then I went to engineering school and spent all that time never once using the term. Now this is something I only hear non-professionals and chemical engineers say.
The term I have learned to think of when someone says "back pressure" is "line loss" . . . mostly. The problem is, in my mind, the term is unspecific. In the case of the OP I think the term is being used instead of "static head."
So, I think this fellow (in his, not very clearly worded question) is asking about a steam trap (float type?) and the pressure differential across the orifice. Steam pressure on one side as the motive force and a column of condensate on the other side pushing "back" on the needle valve.
In the case of the steam trap, the size of the needle valve orifice, and the size of the float, determines the pressure differential (dp) needed to open the valve. The steam pressure must then be sufficient to overcome the static head pressure of the condensate column on the other side. If the condensate header has positive pressure, this must also be overcome.
I don't know if I have made this any more clear or not. I can only hope that I have helped. Please ask if you need additional clarification.
-A-
question everything
03/07/2013 11:44 AM
For your information the term "back pressure" is used iinterchangeably with "total lift" by a number of condensate equipment manufactures for specifying the required return head for condensate return pumps/systems. Nothing to do with "non-professionals and chemical engineers"
03/09/2013 12:10 PM
links please?
Register to Reply 9 comments
-A- (1); Anonymous Poster (1); lyn (1); PWSlack (1); sabriahmad (1); Tornado (1); truth is not a compromise (2); WJMFIRE (1)
