Previous in Forum: How Do Building Management Systems (BMS) Work?   Next in Forum: Pressure Guage
Measurement Unit for Charpy V Notch Impact Test
03/10/2013 1:26 AM
As per the technical specification of a generator shaft, specification specifies that - " individual values of Charpy V Notch impact test shall not be less than 3.5 daj/sq cm ".
What does 3.5 daj / sq cm indicates ?. Is it deca joule per squre centimeter ?.
What area to be taken into considerartion to convert it to the Joule ?. Is it the standard test sample cross section area (10 mm X 10 mm as per ASTM-370) ?. Generally test results for Charpy V Notch Impact tests is reported in the energy unit Joule.
Pathfinder Tags: Charpy CVN impact test
Re: Measurement Unit for Charpy V Notch Impact Test
03/10/2013 12:28 PM
1 dja = .1 joule.
I am not familiar enough with Charpy testing to comment further.
Good Answers: 38
03/10/2013 2:24 PM
Zazu....
This ancient (113 year old)ductility test is meant to empirically detect the brittle transition temperature for a particular metallic specimen. Results are in units of energy FOR A PARTICULAR SIZE OF SPECIMEN.
Look up the standard specimen size on Wikipedia and in ASTM 370.
03/10/2013 11:16 PM
When I did some of this 30 some years ago the units we used were ft-lb @ temperature. In our case most wanted at least 15 ft-lb @ -20 degrees. The specimens were a standard size.
Lehman57
03/11/2013 5:56 AM
The units are important, check the evaluation/comparable values are the same units, there are two terms or specifications resulting from this test, temperature at which the test is done, usually -20, -30, -40, -50 ºC (or equivalent in other units like ºF), and Joules obtained as a result (energy). there are normalized test piece dimensions, please see the quality norm EN 10045/1 taking into account that ASTM E-23 norm has some differences related to the impact shapes.
If you want different results, don't do always the same (A. Einstein)
03/10/2013 11:45 PM
One decajoule (which I think your abbreviation means) is 10 joules. I don't think it is a commonly used or standard unit.
03/10/2013 11:51 PM
Ok. I'm wrong again.
03/11/2013 8:51 AM
easy mistake since both use lower case 'd':
dJ=deci-Joule (0.1*J) while
daJ=deca-Joule (10*J), 'a' making the difference
Unlike the use of lower/upper case in milli- and Mega- to differentiate
Register to Reply 7 comments
Javier Aseguinolaza (1); Lehman57 (1); lyn (2); miklosh (1); MJCronin (1); Tornado (1)
