Previous in Forum: Pressure Guage   Next in Forum: Turbines
Sanyo Split Unit Air-Conditioner
03/11/2013 6:31 AM
I want to buy an air-conditioner with 24,000BTU. the supplier delivered an air-condtioner with the following specifications:
COOLING CAPACITY: 7kW
ACTUAL COOLING CAPACITY: 21.500BTU
I understand 7kw is equivalent to 24,000BTU
What is the difference between cooling capacity and actual cooling capacity as far as aircondition specification is concerned.
Rgards
Mtonyole
Re: Sanyo split unit air-conditioner
03/11/2013 6:38 AM
Depending on the size, method of construction, insulation level and power dissipated within the building, the difference may be between a fraction of a degree and several degrees celsius.
03/11/2013 7:20 AM
Add insolation/cloud cover, day length, and air temprature/humidity/barometric pressure to that list of variables.
Good Answers: 444
Re: Sanyo Split Unit Air-Conditioner
03/11/2013 12:13 PM
There are losses in all real devices, nothing is 100% efficient. Your AC draws the equivalent of 24,000 Btus, but only does the cooling equivalent of 21,500 Btus. The "missing" 2,500 Btus goes into the work of moving the refrigerant around, removing the heat from the compressor, and running the fans that remove the heat from the coils.
03/11/2013 1:02 PM
Thanks for a good answer
03/11/2013 5:22 PM
"nothing is 100% efficient"
An electric furnace within the ' to be conditioned ' space is 100% efficient....
Good Answers: 444
03/11/2013 7:00 PM
As long as you're splitting hairs, there are losses in the lines leading to the conditioned space, but I agree that it is 100% efficient converting the energy that is presented to it.
03/13/2013 3:02 PM
When i want to buy an airconditiner should i specify the nominal Cooling capacity or the actual cooling capacity? and why?
Register to Reply 7 comments
dmtonyole (2); PWSlack (2); RAMConsult (2); SolarEagle (1)
