Previous in Forum: DC-3Hz low pass filter with 200ms rise time and fall time   Next in Forum: ph Measurement of Soil
4-20ma circuit
05/29/2007 2:03 AM
I want circuit diagram for 4-20ma circuit
input=0-5v
output= 4-20ma with 24v sourse which can drive 1k ohm load
please help me
Pathfinder Tags: Circuit diagram
Re: 4-20ma circuit
05/30/2007 12:40 AM
http://focus.ti.com/docs/prod/folders/print/xtr117.html
Re: 4-20ma circuit
05/30/2007 2:21 AM
The XTR products cannot drive 1kohm. Watch your compliance voltage in 4-20mA applications.
Re: 4-20ma circuit
05/30/2007 2:30 AM
Are you sure? I actually didn't look at the datasheet. In any event:
http://www.analog.com/en/prod/0,2877,AD694,00.html
Here is one spec'ed to drive a 250 ohm load and if that's not enough there is an exampl of how to add a current boosting transistor to the output.
Good Answers: 18
Re: 4-20ma circuit
05/30/2007 10:54 AM
XTR117 is rated to 40 V. 40/1K = 40 mA. More than enough compliance voltage at 40V. At 24 V supply, you could get 24 mA (less a little for loss).
Re: 4-20ma circuit
05/30/2007 7:13 AM
Posts 1>4 will give you good products;
But:
Want to rig up a DIY circuit with not a high accuracy-all analog-mind you ?
3 or 4 Transistors+that few resistors+ 24VC battery is all you will need.
Many in CR4 will come up with brilliant solutions!
Re: 4-20ma circuit
05/30/2007 4:57 PM
Please see another discussion. A lot had been discussed there:
http://cr4.globalspec.com/thread/2905/4-to-20-MA-Source-Circuit-Diagram
<4 to 20 ma source circuit diagram>
Register to Reply 6 comments
Anonymous Poster (1); Bill (1); Haajee (1); MUKULMAHANT (1); rcapper (2)
