Previous in Forum: Centrifugal Pump Calculation   Next in Forum: LG Washing Machines
10 comments
Location: kibbutz nir-david, a beautiful rural village in Israel
Drive Belt Data Needed - Marloni Spectra 1023H
03/15/2013 1:45 AM
Dear friends- yesterday I boughta drive belt, Marloni Spectra 1023H. I asked the dealer for the exact specification of it- his answer was , that he doesn't know, but I'll find them if I google Marloni Spectra 1023H, I spent many hours but didn't find nothing relevant!
please help me! thanks in advance.
Pathfinder Tags: drive belts
Re: drive belt data needed
03/15/2013 4:51 AM
Go back to the dealer and press for a response, saying that a purchase order is on hold until the information arrives.
03/15/2013 6:51 AM
What do you mean by "exact specification" of a drive belt?
Good Answers: 137
03/15/2013 7:16 AM
Exactly. If it fits, why not just install it? If it doesn't last long it's not likely to cost an arm and a leg, and you can try harder next time.
Good Answers: 49
Re: Drive Belt Data Needed - Marloni Spectra 1023H
03/16/2013 1:29 AM
I am confused. Why would you buy a specific drive belt if you do not know its specifications?
Were you buying a defined SIZE or LENGTH of WIDTH/DEPTH?
What caused you to buy it in the first place?
What difference does its specifications make?
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
03/16/2013 5:12 AM
Well -the story about this drive belt begun as I asked a friend of mine- Asaf, who is a machines engineer about a drive belt which is flexible enough to be mounted on a very small diameter shaft, so Asaf recomended me a belt for washing machine, that he claimed from his own experience, to give a good answer for what I need. The dealer gave me this belt, but I want to be sure- probably it will be better to use 2 belts on the same shaft for the torque I need.The torque is very important for me. I assume that anyway this belt will sustain 1000r.p.m without any problems.
03/16/2013 2:48 PM
As long as you have a pulley on your shaft, that's real close to the size on your standard washer, you should be fine-or a double pulley, in this case. If you don't, the belts won't hold up long. You will also want to make a tensioner.
03/16/2013 3:34 PM
Mr. Native, you could not find anything on Google because I suspect your spelling was incorrect. It's not "Marloni"...try Merloni as in Ardo Merloni washing machines. You'll get a number of hits for replacement belts. You will most likely not find the specifications you're looking for because these are generic European made components.
Am I correct in assuming you plan to use this belt as part of the drive train for your power assist bicycle?
03/16/2013 4:17 PM
DOUBLE BINGO TO TERRAMANֱ:In fact I was wondering who will be this guy that will decipher this riddle...
And you're correct for the merloni- at least I found this site by myself and without the specifications.The reason that I wrote marloni and not merloni. is that I got the name written unpunctuated Hebrew,so I didn't know if it should be a or e!
03/16/2013 7:42 PM
In that case you may want to look into belts specifically designed for bicycles. I doubt that one made for a washing machine will handle significant torque and abuse for very long. There are many brands available on the market. I don't know what you have in your area but I'm sure many of the European brands are available. Gates Carbon Drive has some nice products. I have one on my mounain bike. Good luck.
03/17/2013 12:56 AM
Dear Terraman- After that the owner of the store where one of his employes- the "expert" gave me the worm gear reducer-said that the worm gear is very inefficient, I decided to solve the problem with a belt drive, that will enable me to reduce the engine's r.p.m about 12 times, with minimum weight and cost!
Therefore I was looking for a very flexible belt, and Asaf told me that this washing machine belt will provide the best solution.
Since I do not plan to use this bicycle more than 2-3 hours per week, I hope that this belt which costs about 13$, will endure about 1 year.
Anyway I plan to use as much as possible from my own muscles and fitness, so it will reduce some of the strain on the belt!
Register to Reply 10 comments
az native (3); Codemaster (1); energygod (1); N. (1); PWSlack (1); TerraMan (2); Tornado (1)
