Previous in Forum: Pump Discharge   Next in Forum: Locating a Pressure Booster Pump
42 comments
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Need Hand Cranked Gear Box
03/18/2013 11:32 AM
I can't seem to locate the type of manually cranked gear box that I need. Similar to a winch, but I need to be able to attach a 20' round bar shaft to it.
I have a theoretical design, but can't quite find the components.
In basic terms, here is my design. I have a 24' long X 5' wide X 7' tall structural frame, made of heavy rec tube. I have two tables within this frame. On each table, there is a 1600 lb steel slab, 20 feet long x 12 inches wide. The design challenge was to find a method to raise then lower each of these slabs one at a time, 4" while keeping them level in all planes, and not allowing any bending during this lift.
The method I've come up with uses a winch or gearbox, manually operated, suspended to the top end cross member. This gearbox needs to turn a 20' long round bar that runs the length of frame, suspended by pillow blocks in 4 places. There will be 4 small spools welded along this bar. From each spool will hang two wire ropes.
When the crank is turned, the 1600 lb slab will be lifted by way of 8 connection points at the ends of the 8 wire cables, the cables wrapping around the spools, to a height of 4". Hands and arms will be put under these suspended slabs doing various maintenence related things. Then the slab is lowered with the hand crank, cables disengaged, gear box slides over 18" along a short trolley to center itself over second slab, and operation is repeated.
I can see the hand crank gear box in my head, but can't seem to locate one that will do what I've just explained. Could I get any help on this?
My first choice was to use a manual chain hoist type of thing, but there is nothing like that, that I can attach a shaft to, that a cable can wrap around. I was thinking of the hoist used to lift industrial overhead bay doors. But those shafts are actually within a tube. So I've moved to a manual gear box, if I can find one. AKA "Hand Crank Gear Drive", or "winch that will accept a shaft".
Re: Need Hand Cranked Gear Box
03/18/2013 11:39 AM
Can a manual boat winch be converted to do as you wish?
As I consider, there must be something out there that already works without converting, but I can't think of one either.
[edit] "...a manual chain hoist type of thing, but there is nothing like that, that I can attach a shaft to..." Hmmmm, this sounds like the operating principle of a manual coiling service door.
Good Answers: 39
03/18/2013 11:46 AM
A boat winch came to mind as well, but the way they are put together, generally it doesn't really have a thru-shaft. Do you know, are they strong enough for a 1600 lb vertical lift? Like I said, a chain hoist would be great, but again, can't attach a shaft to it.
Good Answers: 39
03/18/2013 11:57 AM
Yes, like a service door. At least visually. But those actually involve a long tortion bar within a tube. So I can't put pulleys on it because the rotating part is not exposed.
03/18/2013 12:10 PM
"... But those actually involve a long tortion bar within a tube." Negative, rolling service doors work on a jackshaft.
Bingo! Look for "jackshaft chain hoist".
Good Answers: 39
03/18/2013 12:25 PM
What would you know about doors?
Oh yeah... never mind.
Well... I contacted a company named Lift Master that does overhead industrial bay doors, and discussed the whole issue with them. That's who explained to me about the torsion bar thing I mentioned. And he could think of no other solution.
It seems that "jackshaft chain hoist" is slightly different, at first glance. And is actually what I was picturing in my mind. Hopefully it is different. https://www.garagedoorstuff.com/product/garage-door-chain-hoist-jr-jackshaft/
could possibly be what I seek. I'll have to give them a call.
At this point, definitely a GA though!
03/18/2013 1:53 PM
The garagedoorstuff link shows a lightweight version of what I am suggesting.
Yeah, people like LiftMaster make stuff for sectional doors... upward acting doors that are in sections (usually about 2 foot tall) and store open in more or less the same fashion as when they are closed (e.g. a residential garage door). A rolling service door is so called because it rolls around a shaft to store when open (the jackshaft).
Cornell Iron Works, Cookson, McKeon... these are the guys to contact that I am aware of. Every door is made to order, they shouldn't have any real trouble making what you need. These guys all work through dealers, so a trip to the yellow pages for a local guy might get better results.
Good Answers: 39
03/19/2013 8:30 AM
That's a good education on lift doors. Thank you. Evidently, a "rolling service door" is what I was picturing when I had the idea. LiftMaster should have made me aware of that. I described my project to them same as I did here.
I started with Cornell Iron Works website. It looks very much like what I was looking for. Will be giving them a call this morning.
Good one. Thanx.
03/19/2013 9:57 AM
You're welcome my friend. Glad I was able to offer the idea.
Let me know if you need more info.
03/18/2013 11:42 AM
I'm having a hard time picturing what you're doing, but if I'm close, you may want to introduce some hydraulics. This can be manually operated:
http://www.toreuse.com/hydraulic-workshop-press-motor-or-hand-operated-hsp-110m-1500/
Here's another:
http://www.esskay-group.com/Hydraulic.html
Good Answers: 39
03/18/2013 12:26 PM
This has potential. I may keep it as back up plan E. I'm already on plan C.
Good Answers: 18
03/18/2013 11:46 AM
Hi,
What about these? Powerjacks they are screw jacks that can be connected with shafts to lift in unison.
Best of luck,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
Good Answers: 39
03/18/2013 11:54 AM
Right. I already went the powerjack route. All types of jacks. But there really isn't enough room under the slabs. there are other components in the way. The only jack that would fold flat enough was a scissor jack, and without complicated gearing and modifications, those can't be hooked together to lift in unison.
Pretty much, the only option is a lift from the top.
The reason for this whole thing is for maintenance. Lifted once every six months. And it is an after thought. It should have been designed into the original design of the machine. The designer had a different lift method in mind, but it turned out to be impractical. So we must be adaptive and find a fix to this problem. The winch idea is what was deemed best... if I can find the parts.
03/18/2013 10:33 PM
The only jack that would fold flat enough is a scissor? Ever hear of a Porta-Power? Put a rigid frame of another inch under those section plates, use two lines-lifts off of the same tube. 4"? No problems.
03/18/2013 12:03 PM
What about modifying an old 4 speed pickup transmission with a granny gear? You would have to devise some type of ratchet and pawl so it doesn't get away from you.
Good Answers: 39
03/18/2013 12:13 PM
That is the right kind of mechanism, but I'm not an expert in designing a ratchet and pawl, to the extent where I'd want someone to put their arms under 1600 lbs supported by that ratchet. Not in the couple days that I have available to me. Hoping for an OEM item.
Good Answers: 104
03/18/2013 12:50 PM
Worm gear reducers are widely available in various sizes, mounting options and ratios, and with various input and output shaft arrangements. The top right one in the picture below should be about right. It has a hollow output shaft and keyed solid input shaft. Maybe adapt a crank to the input shaft? You wouldn't have to worry about back-driving with most gear ratios.
Good Answers: 39
03/18/2013 1:15 PM
You're right. There is no difference between a manual reducer and a powered reducer except the crank handle. This may be it. For 1600 lb, maybe like a 30:1 ratio. On a 1.5" dia shaft, that seems like it would work pretty well. Easy enough to mount on a trolley.
Anyone see any issues with this?
If not, looks like Doorman and bigg have both been a big help. Thank you.
03/18/2013 1:35 PM
Just another thought...
If you were able to use counterweights, you would be able to get by with a very lightweight cranking mechanism.
03/18/2013 1:52 PM
Why not use a winch with the cable wrapped around the round bar, or around a spool attached to the bar?
Here's an example. It's a very simplified sketch, but it should give you the idea. The end of the cable would be affixed to the bar (or the spool) to prevent slippage.
Good Answers: 39
03/19/2013 12:22 PM
Good idea. Except at the midpoint of shaft. Might do this.
03/18/2013 1:55 PM
Realize that I'm late, but this may be another idea. You may need an intermediate gear→
Helical gears
Top: parallel configuration
Bottom: crossed configuration
Good Answers: 266
03/18/2013 2:04 PM
Chain hoist. Just cut the lifting chain. Loop it to itself to make a belt and run it to one of theses. http://rpscoinc.com/chain-sheaves/.
I'm sure one of these can be machined to fit the shaft.
Good Answers: 69
03/18/2013 2:19 PM
Big worms, big sprockets, big chains; the red "bushing" like thing is a ball carriage (you'll need 8).
We lift 12,000 pounds like this everyday; ask Perfecto, a material handling machinery manufacturer, for the punch presses stock rolls.
Good Answers: 39
03/18/2013 2:34 PM
Okay, just ran the worm gear reducer idea through. That was the best idea. But after spec'ing out the ratios and configuration, "the man" doesn't want to spend the $1600 on the one I need.
So that one is out. Lots of good ideas here. I'll be running through them one at a time. Thanx folks.
Good Answers: 69
03/18/2013 4:46 PM
If the company doesn't have the money for that, the elevator should be simply put on hold 'till the budget heals; instead of having to improvise a maybe not so safe solution.
But if "the man" just thinks 1600 dollars is too much to spend on any part of the machine, well, things are much worse...
What happened, did your company issue a quotation on advance, before carefully considering the design ? and now you're tight on cash ?.
Good Answers: 39
03/19/2013 8:11 AM
It's not just $1600; that is the price for the gear box only.
The machine is built and is due for delivery. The feature that was designed to raise the platforms does not work as was hoped. We are adapting by finding an alternate method.
The project was handled properly. Sometimes new custom built designs don't work on the first try. That's the nature of the business.
03/19/2013 12:42 PM
The custom machinery business is so much fun!
Have you exhausted all potential sources for the worm gearbox? Did you try Rhino or other imports? The worm gear adds the added feature of not back driving at higher ratios, which is good for safety of your personnel and gear.
Have you considered mounting 2-4 chain hoists to your frame and driving them together with a jack shaft? We lift big plates with a crane and spreader and 4 chains safely pretty regularly. When not in use, store the rigging out of the way.
Good Answers: 266
03/18/2013 4:23 PM
I believe the gear box your looking for is called a torque arm, shaft mount reducer.
Most come with taper bore for a shaft adapter.
Good Answers: 39
03/19/2013 8:25 AM
Thank you ozzb, I'll look into this type of reducer.
Good Answers: 21
03/18/2013 8:33 PM
I do not know what country your from so knowing the agency that over sees safety is a guessing game. But, I see a hole lot of issues with raising a plate as you have stated. Are there persons going to be working under and around this equipment while suspended? If so you have now opened the other can of worms.
I would not venture to offer any suggestions for this issue other then to suggest finding a good qualified engineering firm to work with you so all bases are covered. Then you might speak to your insurance carrier before proceeding.
Good Answers: 39
03/19/2013 8:20 AM
We are a good qualified engineering firm; not a bunch of guys working out of a garage.
I'm asking for creative ideas about a design challenge, from anyone interested in offering clever suggestions to help out. That's what we do here... Not asking for legal warnings and lectures. If you have reservations about offering ideas, feel free to not participate. Thank you.
03/18/2013 11:10 PM
OK, so you want cheap. Around the turn of the last century there was the problem of pulling up tree stumps from the ground. So what was devised was a frame like you envisioned, the 2" or so turning shaft had a HUGE wheel attached to one end, like 10 feet in diameter. Then a team of horses pulled the rope or chain wrapped around the big wheel. Substitute a cheap wire winch for the horses. For safety,throw a pair of railroad ties under the slab ends. If the ties get compressed go for 2 at each end. If you need a big wheel at each end of the torque shaft, ok go with two winches.
This may be an extreme Keep It Simple Stupid, maybe too stupid....
03/19/2013 6:30 AM
Do you need a gear box at all?
If you make the axle 1" diameter and the crank handle 16" long then you only need to apply 50 lb force to the handle to lift the 1600 lb slab.
Just ensure that the slab has safety blocks placed under it to ensure that it doesn't fall while working under it.
03/19/2013 9:02 AM
How about some air bags?
Good Answers: 39
03/19/2013 9:08 AM
Thank you. Actually, that's been considered. The space that we have available below the slabs doesn't lend itself to that because of its size and shape, and other components in the way. Jacks and actuators were also considered.
I've described what my frame looks like, but those were just the relevant components to this discussion. There is a whole lot more to the machine. The envelope within the frame is pretty full. But we do have room above, that's why I'm looking at a winch type assembly now.
03/19/2013 9:24 AM
Don't forget to add a ratcheting BRAKE!
03/19/2013 10:27 AM
OoBE, I think you can get exactly what you want, just need to look inside the box
  1. The round bar, driven at one end may experience enough torsion to invalidate the assumption that all spools are sych'd and the slab is level.
  2. The drive point attachment to the round bar is a serious failure risk area.
  3. I suggest using a round tube for the shaft, which may also obviate the need for added spools.
  4. Use a cable winch, driving the middle point of the shaft by attaching the cable (wrapped around) to the tube/spool at the mid-point. Winch can be anchored at a convenient height off to the side.
  5. Crank away!
Good Answers: 39
03/19/2013 12:20 PM
Yeah, that's partly similar to what USBPORT sketched out for me yesterday, except for center drive.
I just sketched a design like what you described. It makes sense. I might go with this.
03/19/2013 12:36 PM
sorry USBPORT, I missed your post; just added a GA for it
03/24/2013 2:55 PM
You could do this with a hand-cranked boat winch and some pulleys. From the main cable on the winch, make a crow's-foot of four extension cables, each running over pulleys to suit the geometry of your assembly.
Good Answers: 39
10/17/2013 2:52 AM
Just as an update...
I went with something very similar to what usbport drew in post #15. I had two 20' long bars instead of one. Parallel to each other, about 3' apart. I welded a 6" diameter pulley to the center of each bar. I attached two cables to the single winch pulley, one going across to each center pulley on the bars. When I cranked the winch, both bars would rotate.
Additionally, I had four additional pulleys welded to each bar, two on each side of center. From each of those pulleys, I had a cable descending down to the weight. When the winch was hand cranked, it would rotate both bars, which would rotate all eight lift pulleys, which in turn raised my weight evenly from eight points of contact.
Thanks again for your help folks.
Good Answers: 104
10/17/2013 10:48 AM
Thanks for the feedback.
Register to Reply 42 comments
BGuillot (1); bigg (2); dgibson (1); Doorman (4); fixitorelse (1); geekish (1); jesw55 (1); JRiversW (1); kramarat (2); lyn (1); miklosh (2); N. (1); Out of Box Experience (16); ozzb (2); Randall (1); Tom_Consulting (1); Tornado (1); Usbport (1); Yahlasit (2)
