Previous in Forum: Particles Detection in Salt Water   Next in Forum: Manifold
10 comments
MOV vs AOV
03/21/2013 4:24 AM
Hi guys,
I'm from mechanical background and would like to know the difference between MOV and AOV. What are the things that I need to compare (pro and cons)?
Brief service parameters;
Operating pressure: 125barg
Service : Super heated steam
Pipe size : 10"
I really appreciate if anyone could recommended which is to be chosen.
Thanx in advance.
Pathfinder Tags: AOV MOV
Re: MOV vs AOV
03/21/2013 4:36 AM
Acronymectomy would be invaluable here. If MOV stands for "[electric] motor-operated valve" and AOV stands for "air [actuator]-operated valve", then the answer is in the question.
Re: MOV vs AOV
03/21/2013 5:28 AM
Yes, MOV & AOV are as per guessed (thanx).
Your answer is very tricky tho. I was expecting something from the engineering experience.
Re: MOV vs AOV
03/21/2013 6:34 AM
Tricky be blowed. If air is available, use that as the motive force. If electrickery is available, use that.
Simples. ζ
Re: MOV vs AOV
03/21/2013 10:33 AM
Experience - I am a controls engineer for a small process skid builder. In 25 years of building we have installed a motorized valve one time. That particular skid was totally customer designed and a bit of a proprietary thing. Upon asking the obvious question, why, I got no response from the customer's engineer. Note there were 15 air operated valves on the same skid, so plant air was not the issue. I can only assume it was for the slower response time.
I personally specified a motorized valve for our in plant use for installation reasons - I did not want to go through purchasing and installing a filter regulator and additional air line plumbing for a solitary valve when a 120VAC outltet was 2 feet from the valve location.
That covers some of the reasons for motorized valve use.
Re: MOV vs AOV
12/07/2013 3:22 AM
Dear Sir,"Cair Euromatic Automation Pvt. Ltd" always tries to ease out your burden with the latest technology available and here we take the opportunity to make your company aware about the electrical actuators and motorized valves.We have been awarded ISO 9001:2008 & CE Certified by TUV NORD for Design, Manufacturer & Exports of Electrical Actuator & Micro Limit Switch Box.
Our product range:> Electrical Valve Actuator (Quarter Turn / Multi Turn / Linear)> HVAC Damper Motorised Actuator> Motorized Ball Valve> Motorized Butterfly Valve,Motorized high performance Butterfly Valve> Motorized Damper Valve°> Motorized Control Valve> Motorized Gate Valve> Motorized Globe Valve> Motorized Knife Edge Gate Valve> Motorised PTFE Lined Valve> Micro Limit Switch Box (Weather Proof & Flame Proof)> actuators ball valve, ball valve actuator, valves actuator, actuated ball valve, actuator valve india,motorized valve.
Send us your inquiries. Give us a chance to prove ourselves. Best quality, quick deliveries and trouble free services makes us different from others. We would really look forward to serve you with the very best. Please feel free to contact us. Website: www.actuatorindia.com / www.cairvalves.com
Try our company because we 'Cair'
Clients: http://www.cairindia.in/clients.htm
Thanking youYours faithfully,For, CAIR EUROMATIC AUTOMATIONVasimMarketing Executive+91 99798 58634cairvalve@gmail.com
Cair Euromatic Automation Pvt. Ltd. (CE, CMRI, ISO 9001:2008 Certified by TÜV NORD)Plot No. 177 Shiv Shakti Estate, Near V-Trans, Narol Road.Ahmedabad - 382 405 Gujarat. India.Phone / Fax : +91- 79 - 2573 0189Email : cairvalve@gmail.com | info@cairindia.in
Re: MOV vs AOV
03/21/2013 5:44 AM
Air is typically faster, which may or may not be the desired objective. If the valve must operate during power failure, an air accumulator is probably easier to provide than electrical storage.
Good Answers: 176
Re: MOV vs AOV
03/21/2013 9:16 PM
See this thread on differences between air and electric actuators.
http://www.eng-tips.com/viewthread.cfm?qid=323523
There is definitely application for both.
Re: MOV vs AOV
03/24/2013 3:06 AM
Thanx guys. I appreciate your thoughts.
Actually, i would like to decide whether to use an MOV or an AOV for a shut down block valve on a super heated supply line to a compressor. The OEM recommend that the line shall be isolated within 30mins after the switching off of the compressor. The frequency of this isolation is very low (upon needs or twice a year).
AOV response is very fast (1s/inch) and i don't need that much speed. As for the hammering effect, would that happened if i change the existing manual block valve to an AOV?
For an MOV, in terms of auxiliary accessories that should come with it (eg: cabling), compared to AOV, which one is more in terms of cost/installation/maintenance?
in the mean time, i'll digest the link given. thanx.
Re: MOV vs AOV
03/26/2013 5:26 AM
If you do not need to control the flow only to open or close the valve then use MOV.
MOV used also for replacing the mechanical hand operated valve where operate do not reach easily or time consuminng like Boiler main steam valve.
Re: MOV vs AOV
03/28/2013 2:46 AM
Thanks Lalit.
Register to Reply 10 comments
cairvalve (1); Iris (1); Lalit Shukla (1); Mohd Sukri (3); Phys (1); PWSlack (2); Tornado (1)
