Previous in Forum: How to Find the Area Intersection Between Two 2D Entities in Inventor?   Next in Forum: MS Outlook Data File
Help in PLC Program
03/25/2013 1:34 AM
Can you please help me on the following program:
ABB CODESYS
· PLC Configuration
· Design the program(CFC (Main Program) and LD)
· Log in
· Run and Simulate
Resource to Concern
· AC500 PM571 V1.2
· DC522 Digital Unit
· Ax521 Analogue Unit
MAIN PROGRAM (CFC)
On chemical plant two tanks (T­_1 and T_2) exist that flows into third tank (T_3).The level of Tank (T_1 and T_2) is monitored by level sensors connected to the first and second analogue inputs of the PLC Modules. The sensor gives a signal of 0V for the LoLo value and a 10v for the HiHi value>the following condition will need to activate a different alarm condition:
· T_1 Level <T_2Lvel active condition on the first output of the DC522
· T_1 Level >T_2Lvel active condition on the Second output of the DC522
· T_1 Level =T_2Lvel active condition on the Third output of the DC522
A PUMP connected to the system (fourth output of the DC522) consisting of T_1 ,T_2 and T_3 is used to pump chemical from T_1 and T_2 to T_3.This pump will stop after 5 seconds if an alarm condition is triggered. The PUMP can only start when it is manually activated with START_1 xor START-2 N/O push release buttons buttons ( First and second input of the DC522 ) after a 3 second delay.
SECOND PROGRAM
If all three he alarm condition are triggered a fifth output on the DC522 must be set and can only be manually reset with a third RESET _1 N/O INPUT ON THE DC522.
Good Answers: 38
Re: help in PLC program
03/25/2013 1:53 AM
Check the manuals and examples on the internet and do some studying?
Re: Help in PLC Program
03/25/2013 2:39 PM
Good Answers: 151
03/26/2013 4:49 PM
I am not familiar with ABB PLCs or their programming environment, so I can't help you there. However, I think what you are struggling with is where to begin with the specific problem that you have been assigned. This is how I would approach the problem, regardless of what PLC system I am using:
  1. Identify the discreet inputs and outputs that you require and assign them addresses in the processor using tag names.
  2. Identify the analog inputs that you require and assign them tag names or addresses and convert the values (0-10 volts) to meaningful engineering units, for example x volts=y liters
  3. Now develop your logic. A simple flow chart is a good way to start.
  4. Using your processor's instruction set, Convert your logic diagram to specific instructions.
03/31/2013 10:48 AM
I think my biggest problem , is to write instruction for the following condition:
· T_1 Level <T_2 Level active condition on the first output
· T_1 Level >T_2 Level active condition on the Second output
· T_1 Level =T_2 Level active condition on the Third output
Can someone please help me on how to write a program irrespective of software which one is using to fullfill above condition . That is all that need the rest I will do it my self.
i.e how does one write those instruction or program the instruction so that when I run the program ,it will fulfill the above condition .
if sensor t1 is less than sensor t2 I want the result on output 1
if sensor t1 is greater than sensor t2 I want the result on output 2
if sensor t1 is uqual to t2 I want the result on output 3
I need the above instruction on a plc language ,any language.
Good Answers: 38
03/31/2013 8:48 PM
These are basic PLC programming.
Try to check some documentation
http://www.wago.com/wagoweb/documentation/759/eng_manu/333/m07590333_00000000_1en.pdf
Good Answers: 54
05/21/2013 8:22 AM
The problem seems simple enough but I don't work with ABB plcs so I can't help you with the exact programming. Besides, the problem seems too simple to be a real problem in a factory. It's homework, right?
Also, in the real world, T1=T2 will be ON for only a split second due to noise or turbulence in the levels. Your output no. 3 will be flickering like a candle when the two levels are close enough.
regards,
Vulcan
Register to Reply 6 comments
Epke (2); gringogreg (1); jack of all trades (1); ndousm (1); Vulcan (1)
