Previous in Forum: 2001 Astro Van   Next in Forum: The Jaguar C-X75
11 comments
Accessing Impact force and Speed of Side Collision
04/09/2013 5:01 AM
I was hit at the side by a Toyota Comfort (around 1800Kg) while driving a Porsche Cayenne SUV (around 2070Kg); both of the front and read doors were damaged and need replacement; moreover B piller of my car also need reshape and align. I need some advise as how to assess the speed of the taxi causing such.
Good Answers: 145
Re: accessing impact force and speed of side collision
04/09/2013 5:28 AM
If you are looking for legal reasons then you probably need to hire an expert. I don't know what country you are in but (as far as I know) in the U.S. you must be accepted by the court as an "expert" before you can present opinions, calculations, etc. Even if you have the right answer and have calculated it correctly I don't think you can present the evidence.
If you are not looking for a legal reason then it is an interesting exercise but the most logical answer is probably to accept the information in the police report.
Note that I am not a lawyer and I am not qualified to give legal advise. These are just my opinions.
04/09/2013 5:38 AM
Thanks Bruce. I am in HK, which doesn't required pre-qualifaction as an expert. I got a professor willing to help but he needs help as where to find such information.
04/09/2013 5:53 AM
[A few phone calls to Toyota's crash testing centre/center] seems to be the route to the solution.
Good Answers: 918
04/09/2013 7:15 AM
Why? My guess is that it helps your case.
There are outfits and experts that specialize in these types of accidents - obviously, for a fee.
However, that fee may be well worth the price. The reason is that an "expert" witness with credentials caries far, far more legal weight than a bunch of anonymous would-be engineers on some internet forum.
My "unprofessional opinion" is to contact a "good" accident attorney.
P.S. I have been known to be right. :)
Re: Accessing Impact force and Speed of Side Collision
04/09/2013 12:56 PM
Albert, if you send fotos and measurements to the Porche people they should be able to help....I suppose thay have done such tests that should carry weight!
Good Answers: 918
04/09/2013 1:02 PM
My bet is that they will not. Porsche will not want to expose their @ss in any legal way. Their attorneys will prevent release of any such information faster than light.
You would need to subpoena that information and I would bet the only way you could do that is if the court and the attorneys see Porsche is possibly liable in this case.
04/09/2013 3:28 PM
The car manufacturers will likely not want to get involved but you may be able to get information on their crash test program (possibly videos) from the internet and use this to compare to your damage. Accurate speed and damage assessment is VERY difficult due to vehicle crumple zones which vary from car to car.
Try seeing if there is video of the accident (street camera's, public cellphone video, etc). A long shot, but if you can find it you can us it to work out the speed.
Witness testimony seems like the only realistic option. What do both insurance companies say?
I am assuming the taxi driver was in the wrong, if you were and the accident is your fault then all bets are off and it likely doesn't matter what speed the taxi was traveling.
04/10/2013 3:54 AM
Thanks Jack. I am sure that I was following the traffic light but need to prove it. Thus would like to access the impact force needed in causing such scale of damage to calculate the speed of the taxi during collision; and then basing on its distance travelled to proved that it wan't just started from stagnation.
Good Answers: 266
04/10/2013 2:04 PM
I found this accident investigation calculator which may help. If you google the term or impact calculators you may get others. If you took pictures that would help. The length of the Toyota's skid marks before impact and the distance it drove the car are a better factor to base speed on. It is this speed you want to determine if the car was stopped or not at the intersection before he started forward.
http://www.greatrix.co.uk/AICalculator.html
04/10/2013 11:23 PM
Thanks Ozzb very much. I feel the simulation program would be very help; any suggestion how I could obtain the stiffness coefficient of both vehicles as well as the coefficient of friction of the road surface?
Good Answers: 266
04/11/2013 7:43 AM
http://www.aras360.com/resources/vehicle-stiffness-database.html
As far as the coefficiant of friction of the road surface. You should be able to find a listing of it. Which would be determine by the type of surface and it's condition wet or dry.
Register to Reply 11 comments
Albert Ho (3); Anonymous Hero (2); BruceFlorida (1); jack of all trades (1); jurie sa (1); ozzb (2); PWSlack (1)
