Previous in Forum: Hypothetical Water Displacement Puzzle   Next in Forum: Texas Fertiliser Plant Blast
25 comments
Stainless Steel Crimp Terminals
04/17/2013 6:18 AM
Does anyone out there know where to purchase Stainless Steel Crimp Terminals in the USA for copper wire? I am looking for a size that fits AWG #4 with a 1/4" stud. I have searched Google long and hard with NO LUCK! I picked SS because these terminals will be submerged in DI water for there lifetime.
Re: Stainless Steel Crimp Terminals
04/17/2013 6:32 AM
Submerged?
04/17/2013 6:35 AM
Yes, They are going to be used ground connections on EDM Machines.
04/17/2013 6:37 AM
Why submerged though? Go on. Do tell.
http://www.acronymfinder.com/EDM.html
04/17/2013 6:41 AM
Wire EDM Machines have Lower Heads that are submerged in a tank filled with DI water. Common Copper and Nickel Plated terminals are attacked and eaten away by the DI water that causes both Electrical and Mechanical Failure. SS will avoid this problem all together.
04/17/2013 7:39 AM
So, make the earth/ground connection outside the tank.
04/17/2013 8:29 AM
PWSlack... You obviously do not have a Clue about Wire EDM Machines and there construction.
04/17/2013 8:30 AM
Do explain all, for there will be others. After all, there's only 75 acronyms to work through.
04/17/2013 10:58 AM
Pitiful… I thought CR4 was here for serious topics, discussion and help. Obviously with members like PWSlack and Del the cat this is no longer the case. Please go back to slacking off and cleaning your cat box and let serious members continue on.
Register to Reply Off Topic (Score 8)
04/17/2013 3:44 PM
There's nothing like a little conceit to get the forum going!
Anonymous Poster #2
04/17/2013 4:37 PM
Our serious members are ready to help !!
04/17/2013 11:01 PM
VLY,
You are obviously very new here.
You came here for FREE HELP.
For a task that any novice purchasing agent would have completed without tutoring from people who have paid for the education, or have the experience, that you lack.
I'm sure we'll all jump right on your problem for you.
I know I'm on it.
Good Answers: 266
04/17/2013 1:37 PM
The lower head is movable. It has linear guides motion on the ones I've seen was done with ball screws. Running current thru them to ground would soon destroy the accuracy. Just as the current on the wire erodes the work piece it would also damage these parts.
04/17/2013 6:41 AM
Have you got the crimps?
No, I always walk this way
04/17/2013 7:38 AM
Good Answers: 266
04/17/2013 7:06 AM
Look at hi temperature terminals. A lot are nickel plated stainless.
04/18/2013 6:29 AM
Thank you for the one and only intellegent answer! I have looked into Hi Temp terminals but none I have found are a sealed barrel like the one in the Picture I have posted.
04/18/2013 8:53 AM
VLY,Could you only find 3 GA's of mine to sabotage???No wonder you can't find any terminals.
04/17/2013 9:44 AM
If you want the excellent free help and advice which is often forthcoming on this forum, I suggest you pull your neck in a bit before some one gives you a good verbal slapping.
Maybe you should check out the number of posts and GAs (Good answers) of the responders, before shooting from the hip.
I'd also suggest you observe good engineering practice and write out acronyms in full after their first usage.
In summary, don't be a tw*t.
04/17/2013 12:02 PM
twat? one of these?
TWAT There Was A Time (Guns n' Roses song title)
TWAT The War Against Terrorism
TWAT There We Are Then
TWAT The Word Association Thread (game)
TWAT Tactical Women's Alert Team (Cheech & Chong skit)
TWAT Ten Worst Automobiles Today (Truth about Cars)
TWAT Texas Women Anglers Tournament (Corpus Christi, TX)
TWAT Trans Wisconsin Adventure Trail (est. 2008)
TWAT Traveling-Wave Amplifier Tube
TWAT The Warm As Toast (cafe in Cardiff, Wales, UK)
TWAT The Western Area Tourers (motorcycle club)
TWAT Tactical Wire Assault Team
TWAT The Watchtower Apocalyptic Testament
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
Register to Reply Off Topic (Score 15)
04/17/2013 1:05 PM
Nah, wasn't an ancronym, just a UK slang expression,the meaning of which should be evident from the posts.
Maybe it's obvious in the US but in the UK these machines are commonly referred to as spark erosion machines rather than EDM.
The OP (original poster) seems unaware that not everyone here is in the US, and interestingly the machines were invented and developed outside the US too.
04/17/2013 7:40 PM
You might be able to find some of these connectors from aircraft supply.....found this don't know if it's SS, but you can check...
http://www.steinair.com/store.cfm?tlcatid=26
Electrical Discharge Machine....
04/18/2013 2:42 AM
If the DI water corrodes copper terminals, what keeps it from corroding the copper wire itsslf?
Using the search term "stainless crinp terminals", I got gazillions of Google hits. What search term(s) did you use that returned no hits?
04/18/2013 6:25 AM
I have found SS terminals like the one in the picture that when sealed around the barrel with silicone and heatshrink will stop the De-Ionized water from attacking the copper wire. BUT they are not made in the USA! I have Googled this and all of the suppliers are not in the USA! I am looking for a small quanty and this is where I am running into problems.
04/18/2013 8:23 AM
I hope they cost $1000 apiece.
04/18/2013 10:53 AM
It occurs to me that you could possibly make these on your machine...? If not some SS pipe and washer could be welded, both of which are universally available....
Register to Reply 25 comments
Anonymous Poster (2); lyn (2); Mike W (1); ozzb (2); PWSlack (5); SolarEagle (2); Tornado (2); user-deleted-1105 (3); VLY (6)
