Previous in Forum: Sewage Treatment Plant   Next in Forum: Rubber Strip
Makeup Water Tank
04/18/2013 8:56 AM
What is the purpose of the makeup water Tank in Chiller Plants?
If it is to be, it is upto me
Re: Makeup Water Tank
04/18/2013 9:02 AM
It's where people go who have been fighting?
Or, it holds water to replace the water that evaporates from the chiller?
04/18/2013 9:11 AM
I'll go with #1. It's the designated timeout spot for people that have been fighting, to make up.
04/18/2013 9:51 AM
For the correct answer see the Control Philosophy document for the plant, which should contain sufficient information to explain both its purpose and the basis for its sizing.
04/18/2013 12:40 PM
if it says "make up" it usually implies water is being used in a process causes water loss, the make up replenishes that lost or used water. it could also be thought of "supply water"
04/23/2013 3:21 AM
It could also be thought of as an expansion tank. After all, the pipework is changing volume with temperature, as is the fluid, and accomodating the volume fluctuations would be useful. The forum still doesn't know what is in the Control Philosophy document for this plant. Please explain.
08/28/2013 3:15 PM
Does this chiller plant have glycol in the loop?
If yes then they sometimes install make up tanks (volumes vary on size of loop) with the proper glycol solution, so when the pressure drops from air loss the tank has a pump interlocked to a pressure switch which will make up for lost pressure.
Register to Reply 6 comments
Fredski (1); kramarat (1); lyn (1); pipeit (1); PWSlack (2)
