Previous in Forum: Why Seamless Pipe for High Pressure Oxygen?   Next in Forum: Exothermic Reaction Between PLS (Copper Leach) and Sulphuric Acid
29 comments
Hobbies - RC Aircraft - New Member Old member.  Heidi;  need to develop paper glider technique.  Use to
Underground Parking Between Two Stripes Vertical and Close to the Wall
04/27/2013 1:20 AM
Here is an idea I had: Background: When parking in an underground garage within two painted stripes which are close together, I find myself backing forward and backward to try to get my car in a good alignment between the two lines. When backing out to get a good sight of the painted lines, I need to back out far enough to see the lines. Meanwhile cars behind me might get "up tight" waiting to go thru so they can get to their appointment on time.
Why not have two vertical strips pasted on the wall in a direct line to each of the two painted stripes?
Then comes the problem of what chemistry is involved to get good adhesion of the two plastic strips. Instead of plastic strips, perhaps the use of two painted stripes. A template could be used.
Re: Underground Parking Between two stripes vertical and close to the wall
04/27/2013 4:46 AM
Good concept
(I always carry a rolled up parking space in the back of the car, in case I can't find one ;) )
04/27/2013 6:00 AM
You go in nose-first rather than reversing in for a quick escape ? I'm impressed by your courtesy for impatient drivers, but *%^*-em. Maybe this is why Boudicca had those nasty blade things on her chariot wheels ?
Joking aside, it seems fairly sensible to continue the 'slot markings' up the wall butaren't you a bit committed when you can see them ?. I can't park to save my life, and I always stop to ask directions if lost (honest, I do !). Still, I also paint a dot on the rear window so I can safely reverse around corners. This method fails rather badly if it's not a nice circular arc .
04/27/2013 6:45 AM
Good idea....how about a hump to let you know you are out of the path of traffic and keep the car from rolling into traffic in case the parking brake should be forgotten ? How about sensors in the parking spots to let people entering the garage know where and if, there are parking spots available ?
04/28/2013 2:25 PM
Replying to Comment by SolarEagle: "How about sensors in the parking spots to let people entering the garage know where and if, there are parking spots available ?"
Actually (assuming we're discussing public parking facilities here), why not ASSIGN parking spaces upon entry? Maybe a large "D-45" printed on your parking stub, to be placed in the window. A computer could track which spaces are (supposed to be) filled, a lot cheaper than all that hardware for tracking individual spaces.
Of course it would not account for cars on their way to the exit. One last benefit to a municipal parking facility might be vioation revenue for parking in other than one's assigned space.
04/28/2013 2:45 PM
Being in the "parking business" I can tell you that such systems already exist.
Signs at the entrance to the parking facility,or the attendant, let customers know which spaces are available.
My organization isn't large enough to use these, but, they have been pitched to me.
04/29/2013 12:34 AM
I think that could develop into a good solution. A very visible red light could show where the closest parkin space is available. Also good would be something showing the odds of finding a space in a large parking lot. One sees electronic signs next to the road showing the speed you are going. So electonic signs can be use.
06/27/2014 2:47 AM
Should have gone in another subject area.
06/27/2014 3:22 AM
This is totally off-the-wall (if you'll excuse the bad pun). My stepfather has a very tight limit in order to reverse his car into the garage. He positioned a very lightly hinged piece of wood from the roof so that when he hears the mild 'twang', he knows that the car is reversed to a very precise distance from the rear wall. I'll add that he is one of the most precise drivers I know, but any little helps. Perhaps he did it as a joke to help me, but it's lo-tech that works. With some lateral thinking, maybe a similar idea could be used. I find the type of wing-mirrors that bend to be very helpful .
06/27/2014 12:52 PM
Sorry about the original comment. It was related to "Odds of finding a parking space."
06/27/2014 2:01 PM
No need for 'sorry', as per my comment I had said it was "off-the-wall".Write it off as Kris' stupid humour is not always clear. If there is any fault, it is on my part. Don't feel down or puzzled by it .
04/27/2013 7:24 AM
those additionall lines wont do much to prevent you from caving in someones door or fender, you still have tp pay attion to everything on either side of you
04/27/2013 7:37 AM
Depends on what car you have nowadays....
https://en.wikipedia.org/wiki/Intelligent_Parking_Assist_System
04/27/2013 7:48 AM
Yeah, but it's funny to park so that the person in the adjacent car hasn't quite got enough room to open the driver door . Animal toys are good - the ones that give a squeek when chewed - just afix several around the car, and hey presto you have a cheap alarm system. I'm a bit cheap, so I just duct tape the animal itself direct to the car. Cats are very effective .
04/27/2013 10:08 AM
Good Answers: 119
04/29/2013 11:27 AM
I employed that tennis ball solution once to keep my wife (now ex) from continually running into my radial arm saw at the end of the garage.
She was not amused and I never could come up with a solution to keep her from ripping off the trim strips on the sides of the garage door frame.
Hooker
Good Answers: 61
04/27/2013 9:20 AM
Sounds like a very good idea. Ignore all the detractors!
04/27/2013 11:26 AM
I'd been wondering what to call that system of furry critters on the side of a car. They sort of make a 'yep' noise when out of alignment. Cat-eyes on the road have long since puzzled me, So cute, yet so useful. None of this works with squirrels, though I may be biased
04/29/2013 1:10 AM
How in the world could one get this idea going? Does one have to go to a city council and express this idea to a group of people. That is probably the last thing I would do. Another topic: For city council work who could convince a public pool to provide baskets to put his clothes in at a public swimming pool. Putting clothes, shoes, etc into a traveling bag and taking them out to the pool area is a pain. The good old days one was handed a safety pin with a number on it and pinned it on to his suit . An attendant could easily retrieve the proper basket.
04/29/2013 1:44 AM
Uk common approach is lockers in the changing room. Coin operated, key on wrist strap. Lose coin only if the key is lost.
Madness is all in the mind
04/27/2013 10:02 AM
Why underground only? And you are assuming that each parking space has a wall, which is not true in many cases, especially underground facilities..
Why not just bolt one of these
on the hood of your ride, looking down at the floor, then you can hit the center of the stall every time.
04/27/2013 10:29 AM
You could just mount cameras in the front and rear, and have a switched display in the rearview mirror....you can even get em with night vision...
Mount em on the sides...
You can even go wireless....
Good Answers: 58
Re: Underground Parking Between Two Stripes Vertical and Close to the Wall
04/27/2013 11:44 AM
The painted lines on the wall is a good idea. Having little magnifying mirrors on my side view mirrors helps.
mike k
Good Answers: 179
04/27/2013 10:35 PM
As a Structural Engineer who has design a lot of aboveground and underground parking garages, you're novel idea has merit only if there are concrete walls at the end of the parking spaces. In many cases, this is not the case, because of cost considerations, nor are they needed from a structural standpoint. For underground parking garages, nearly all of the walls are found along the garage perimeter, with exceptions of course.
It would be much better to install vandal-proof flexible (vinyl?) reflectorized uprights at the end of the parking spaces inline with the parking space lines. They could be bolted down into the concrete topping with specially-keyed bolt heads. If you strike them with your vehicle they won't break...
Maybe I should patent this idea!!!!!!!!
04/27/2013 10:52 PM
"If you strike them with your vehicle they won't break..."Well, not really. We have some of these upright plastic reflectors in "my" garages, but they don't last very long.
Two or three encounters with a tire and they're dead.
Good Answers: 102
04/28/2013 12:10 AM
Lots of good ideas here.
My garage at home requires careful positioning of the vehicle to maintain adequate access around the vehicle.
I don't have lines painted on the floor but I do have 300x300 ceramic tiles laid on the floor which provide an excellent grid for lining up.
I manage to get the car backed in and straight and in the right place by looking at where my rear tyre is rolling in relation to the grid on the floor using the drivers' side wing mirror that came with the car. Opening the window and sticking one's head out to actually look at the wheels as I park seems to work ok too.
Has the OP tried opening the window and just looking?
Driver's here are pretty shocking on the road but they are excellent car parkers on the whole. Narrow urban environment and all. The driving license test focuses on parking ability, road rule knowledge is not examined. Go figure.
Just as a PS, when the garage is used as a workshop, the tiled grid on the garage floor is also excellent for lining up materials for marking out and welding or other assembly works nice and square and parallel as required. Makes an excellent surface for marking out patterns with a marker and what not and is easy to clean. Nothing to do with parking but thought I'd share that with anyone contemplating new flooring in their garage/workshop/man-cave.
04/28/2013 7:41 AM
Sounds like a good idea!
04/28/2013 9:20 PM
The external mirror on my car are electronically adjustable from the arm rest so I just adjust the mirror to point down at the ground. Then I can see the line. The passengers mirror is not so good as it is convex. Also, I reverse in and this makes it easier to follow the line.
04/29/2013 12:18 AM
I just looked Periscpe in the dictionary. This might go hand in hand with your comment. Maybe one could invent a pactical instrument similar to a periscope to see the painted lines next to the tires.
12/02/2014 2:40 PM
Correction: Bad --- two vertical strips pasted on the wall in a direct line to each of the two painted stripes?
Should have said: two vertical stripes painted on the wall. Not strips of plastic, but painted stripes. Should not have got into a plastic strip idea.
What type of paint is used for painting house address numbers on the curb in front of resident?
Knowledge of organic chemistry is essential. Chemical ring structure, bonding one element with another, etc. Aliphatic, aldehydes, ketones, on and on. An actual drawing of the ring structures involved.
Register to Reply 29 comments
Anonymous Poster (1); CaptMoosie (1); energyconversion (1); Fredski (2); GM1964 (1); Heidi (5); Hooker (1); JIMRAT (1); Kris (5); lyn (3); mike k (1); Rixter (1); robbump (1); SolarEagle (3); user-deleted-1105 (1); Wal (1)
