Previous in Forum: Image Decomposition   Next in Forum: Choosing a Fuse
14 comments
Spoiled Radio is Spoiled Again, Need Help!
05/02/2013 11:20 PM
A friend of mine let me fix his radio. I'm an newbie and he said that theres no need to pressure and that i can hold on to it as long as i can. The problem is that, the radio turns on, but no audio output and automatically goes to standby mode. I've located the problem where one of the relay coil wasnt properly energized, the circuit breaks immediately. SO i set out to find the source of the voltage and in hopes i could find the capacitor that might have been faulty.
Unfortunately i mistakenly touch the ends of an amplifying IC D1266 with my multimeter while the power is on. Now the radio couldn't even start.
Now i have no idea how to fix this. Is there anyone out there that could help?
Re: Spoiled radio is spoiled again, need help!
05/03/2013 12:21 AM
Get a schematic from the manufacturer and troubleshoot the circuit....or look for a cheap replacement....
Search for wisdom....
05/03/2013 3:25 AM
It sounds as though replacing the D1266 is the first step.
Re: Spoiled Radio is Spoiled Again, Need Help!
05/03/2013 9:35 AM
05/03/2013 9:38 AM
I off-topic'd this myself, due to words in the flowchart some might find objectionable.
05/03/2013 9:43 AM
If I were you, I'd come to grips with the fact that you are lost beyond hope here, and take the radio to a service tech and get it fixed properly.
Then in the future, don't let your alligator mouth overload your hummingbird a$$.
Good Answers: 58
05/03/2013 7:43 PM
OP sounds a lot like me, trying something new. My advice to him is to find night school classes on electronics. I tried to home-school myself on the subject, no joy. I learned a lot, but mostly I learned that electronics is a very deep well.
I have found that googling the device and the problem will get you to some good help sites. It takes a few tries to phrase the question correctly, but I've gotten good help on the internet.
Also, the OP better be ready to spend some bucks on fancy testers. Collecting them can be addictive, though.
mike k
05/03/2013 10:25 PM
CR4 Admin: Spam: This post was modified because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
05/04/2013 3:47 AM
Might sound obvious, but did u look for fuses, or fusible link, and or burnt resistor,trace, diode, voltage regulator etc. Most likely took out something feeding D1266, but u will need schematic. Sam's Photofact out of Indianapolis, In. used to supply schematics for about everything, but haven't needed one for quite awhile and don't know if they are still in business. Try manufacturerer also. Have fun!
United Kingdom - Member - Hobbies - HAM Radio - G7TSP Engineering Fields - Electrical Engineering -
05/04/2013 6:22 AM
The simplest method:
Is the D1266 definately an IC and not a transistor?
If so, download Datasheet for D1266, check for correct Vsupply and connect tone generator @1KHz to input of pre-amp circuit and look for this on the input of D1266 with an oscilloscope, if present check Output pin, if not present, replace D1266.
05/04/2013 6:30 AM
Having searched for datasheet it's looking more likely you are talking of a transistor. You will have to find a multimeter with diode test function and check the junctions of the device after removing it from the circuit.
05/04/2013 10:37 AM
First search on Google for a schematic of the radio you are attempting to fix
Second after you get the schematic in your mind follow the radio signal from the antenna to the speaker and ask your self "Do you understand what is happening at each component the signal passes through?".
If you do then you will be able to find the problem and fix it. If you do not then you have two choices
1) Learn how all the components work in a radio. This will take a lot of study and time
or
2) Take it to a repair shop.
I have been fixing radios and electroincs since 1940.
good luck
05/05/2013 6:28 PM
I used to do that kind of thing often
And I had friends who were silly enough to let me learn on their gear.
Finding a circuit for the radio is highly unlikely (though sometimes you can get lucky)
Youve got yourself in a pickle as you have now introduced an extra fault in addition to the original fault - 2 faults are harder to fix than one - but if you have the patience and an eye for detail and plenty of time Im sure all is not lost.
1. Whats the brand and model of the radio - perhaps perhaps we can collectively source a Circuit - Which will make life a lot easier
2. If a circuit cant be found all is not lost just more challengeing. You will need to draw your own - at leats parts of it anyway. From your discription it sounds like a power supply issue (but could be caused by something further up the chain)
If the radio isnt an expensive item hopefully your friend will accept the fact that it was already broken before he gave it to you to fix and and you arent responsible for its demise. I find people give me things to fix because they are too tight to pay some one to fix it.
Post some details of the radio and maybe some pictures and we can see what we can do to help guide you in the right direction.
Bernie
05/05/2013 6:57 PM
its not expensive.. but its been a long time buddy for him.. xD anyway, i tried looking for the circuit.. no avail. but from what i see here is that the board is PCB power board. (luckily they have the sense to sepearate the power board from the others)
05/05/2013 7:27 PM
What is the manufacturers name and model number of the radio that you are attempting to fix.
Register to Reply 14 comments
adlfurball (1); Lemmy70 (2); littlebetter (1); lyn (1); Marv Trott (2); mike k (1); PWSlack (1); RC HELICOPTER (1); saabman (1); SolarEagle (1); Usbport (2)
