Previous in Forum: Frequent Failure of Lightning Arrester   Next in Forum: Busbar Insulation Inside Medium Voltage VFD Converter Panel
8 comments
How To Find Capacitor Ratting of Water Pump Motor?
05/31/2013 12:20 PM
Dear Sir,
I was using water pump at my home & its specifications are mention below, Today's its capacitor has been faulted, i opened its cover & try to find its ratting but there is no any values mention on capacitor body. now please help me which capacitor will be suitable as per motor ratting?
Pump Motor 1HP
RPM 2850
Phase Single
Voltage 220VAC
Your prompt action will be appreciated.
Always Respect Your Seniors. Best Regards, Ahmad Arshad
Good Answers: 181
Re: How To Find Capacitor Ratting of Water Pump Motor?
05/31/2013 9:38 PM
I take it the motor has a rating plate.
Try phoning the motor manufacturer. They will give their prompt attention to you're enquiry.
It won't involve people that don't have the full information making assumptions and wild guesses.
06/01/2013 2:47 AM
Dear Sir,
There is no any name plate available or missing that's the reason i put request to hare.
06/03/2013 3:31 AM
And how is the forum supposed to know, when the motor cannot be seen from here?
06/01/2013 3:07 AM
The last time I had ratting, the little blighters had chewed up the insides of the capacitor. The signs were obvious, and I had no trouble seeing the problem.
Belgium - Member - New Member
Good Answers: 21
06/01/2013 6:12 AM
I guess a capacitor +/- 16 uF 450V will fit, compared with an other 1HP 2Pole 220V 50Hz motor.
Please measure the voltage at the capacitor when the motor is on load, it should be +/- 400Vac. Also compare the current the motor takes full loaded it should be +/- 4.5 Ampères. If the motor is not warming excessief, it will fit.
Information given without any liability.
Good Answers: 25
06/01/2013 6:32 AM
Ask any local shop owner at Lahore, he will guide you.
06/04/2013 11:27 PM
Can you be able to provide the type and dimension of the capacitor. If possibile can you show the picture of it. How do know that the capacitor is faulty? Is there a physical sign of damage on the capacitor, do you understand it's function. What is the motor make. If there is no rating, we can only assist you basing on you giving us the above information correctly. Thanks.
"Whatever your mind can concieve, and believe, it can achieve"...Napolean Hill
06/05/2013 6:48 AM
whats a few micro farads here or there? between friends? you could always just Google 1HP motor, 220V.....and get a real close comparison!
Register to Reply 8 comments
ahmadarshad (1); Fredski (1); nick.mapun (1); Phaddy (1); PWSlack (1); rudy.leurs (1); suresh sharma (1); TonyS (1)
