Previous in Forum: Global Warming Again With a Twist   Next in Forum: Vacuum Dryer Feeding Systems
24 comments
Good Answers: 125
What in the world is this ?
05/31/2013 2:24 PM
About 15 years ago, my company purchased a 10,000 square foot industrial building that was previously used as an electronics manufacturing facility.
The previous tenant fled the IRS and left everything behind, still a dream of mine.
Therefore, we inherited a LOT of electronic components, machinery, etc.
Last week I dug this machine out of a back corner.
Does anyone know what it is ?
Good Answers: 140
Re: What in the world is this ?
05/31/2013 2:53 PM
Looks like it is a type of hot foil stamper. Is there a heated jaw for a stmp block?
Good Answers: 125
05/31/2013 3:11 PM
In the first picture, those green things are vials. There is an adjustment knob between them There is also a counter.
Good Answers: 140
05/31/2013 3:57 PM
The green one on the left looks to be a pneumatic lubricator and the other looks like a filter. There appears to be a large pneumatic cylinder in the center.
Good Answers: 11
05/31/2013 2:55 PM
It's a custom-made, one-off boat anchor. Only needs the chain!
Not likely to be a catalog item, rather a component off of another machine. Looks like some sort of specialized guide mechanism.
People Living in Competition, All I want is to have my peace of mind - Boston
Good Answers: 97
05/31/2013 3:10 PM
A banana bend machine.
Good Answers: 140
05/31/2013 3:58 PM
I bet its a press for pushing hard metal components into curcuit boards.
Good Answers: 445
05/31/2013 5:08 PM
Looks like some kind of tensioner for a coil winding machine. The spool of wire was placed between the cones and the hydraulic cylinder adjusted to keep a certain tension on the wire as it was wound on form on a nearby machine.
Good Answers: 123
05/31/2013 11:01 PM
My guess also is the pneumatic tensioner for a spool while winding.
Bob
05/31/2013 5:16 PM
spool unwinder
05/31/2013 7:36 PM
My WAG is that this is a rarely used expansion part of another machine. Combining the known building history with the obvious pneumatics and large but variable shaft size spool holder, I would expect that this is for adding a press fit part to a printed circuit board.
05/31/2013 8:26 PM
Contact the previous tenant and ask him , or make an ad in the paper and ask about workers used to work at that place 15 years ago, they have the informations you need.
06/01/2013 7:00 AM
While it does indeed look like one side of a hot stamp printer, it more closely looks like a ribbon cutter I once built for Hallmark. With that in mind, perhaps it was a parallel electronic ribbon cable cutter. That would also expalin the relatively large air cylinder that might operate the knife and the rather beefy construction of the frame. The hot stamp foil guide mechanisms I have built and rebuilt have not been that heavy duty.
My shoes are too tight, but it doesn't matter because I have forgotten how to dance.
Good Answers: 104
06/01/2013 10:32 PM
I was guessing a straightener (can't see the working area clearly), but I like OldTooly's answer. How about a close-up of the business area?
06/01/2013 7:06 AM
Wire painter?
06/01/2013 11:23 AM
Last saw my wife on one of these, trying to get her weight down...
Good Answers: 75
06/01/2013 11:20 PM
Have you seen her since, then? Still looking? Gave up?
If so, it might have been her I saw in an "As seen on TV" commercial last week. Looked like the added a belt to it, though. Must be new twist on it.
06/01/2013 1:48 PM
Due to the type of construction used (castings), it appears that it is not a one-off machine. It is some kind of machinery component that can be added to other machines in an assembly line. This is strictly a guess.
Mr.Ron from South Ms.
Good Answers: 125
06/03/2013 1:24 PM
Mystery solved.
I found another one that was almost identical.
This one has a plate that says "Component Lead Former".
Thanks to all for the great guesses, several were uncannily on track.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
06/05/2013 11:29 AM
I work for an test equipment manufacturer, and we have the production capability to build all our stuff on-site. Passive components like resistors, capacitors, etc. can be purchased on reels, and that machine would take those reels of parts, and bend the leads to the proper lead-to-lead spacing, for insertion in a through-hole printed circuit board, after which, the board would usually be "wave" soldered.
With the advent and rise of Surface Mount Devices (SMD's), leaded parts are getting scarce these days. I'm sure we have a few of these "lead formers" out in our "antique equipment" barn.
Tom D.
Good Answers: 123
06/06/2013 9:30 AM
Well, it seems that we have a definitive answer. Any chance you can post a picture from your "antique equipment" barn?
Bob
06/06/2013 4:52 PM
Sorry, they keep it locked up, and I don't feel like trynig to figure out who I'd need to ask to get permission to get in there. I might get asked some questions if I started to snap pictures while I was there :)
Tom D.
Good Answers: 123
06/07/2013 8:59 AM
Can't you just put it next to you next time you sit bare a$$ on the copier?
Bob
06/03/2013 1:27 PM
Johnny 5, Jr.
06/04/2013 5:39 AM
It's not the temperature controller from a time machine is it?
Register to Reply 24 comments
AverageJoe (1); Baffled (1); bigg (1); bob c (3); C-Mac (1); Hendrik (1); Marzoky (1); micahd02 (1); North of 60 (3); OldTooly (1); RAMConsult (1); Randall (1); redfred (1); ronseto (1); szwasta (1); tdesmit (2); Tom_Consulting (1); WJMFIRE (2)
