Previous in Forum: 20 hp Motor Connection Circuit   Next in Forum: DC Motor Field Coils Getting Overheated Often
13 comments
VFD For Submersible Pump
06/19/2013 1:59 AM
Hello Sir,
The pump is a 50hp the starter used is reduced voltage auto-xformer and when we replaced by VFD the vfd is turning hot always what cause this?
Re: VFD for Submersible pump
06/19/2013 3:30 AM
One of the possibilities is a mismatch between the selection of the VFD and the motor it is supposed to be driving.
Switch back to reduced voltage auto-transformer starting, perhaps?
06/19/2013 4:53 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
06/19/2013 6:41 AM
Reported : Spam
06/19/2013 12:11 PM
I think it's time to bid jimmydetectors09, king of SPAM this week a big bye bye.
As in go far away.
Good Answers: 104
Re: VFD For Submersible Pump
06/19/2013 8:56 AM
* Is the motor rated for VFD duty?
* Pumps with high static head requirements, such as submersible well pumps, are often not good candidates for variable speed installation in the first place.
06/19/2013 10:56 AM
Get rid of the VFD and match the pump to the system requirements.
06/19/2013 11:23 AM
One of the possibilities is that the fluid being pumped forms part of the cooling arrangements for the VFD, and the speed of the pump is insufficient to deliver the correct flow. Then, no-one here can see the installation other than the original poster...
06/19/2013 10:45 PM
The pump is a 50hp the starter used is reduced voltage auto-xformer and when we replaced by VFD the vfd is turning hot always what cause this? Your Message: Hello. You don't need a VFD for that pump. Based on the data you provided, the load was designed to run via a reduced voltage auto-transformer circuit. Then, get a soft starter. The soft starter solves that problem for you. It will help in regulating the voltage RAMP without altering the stipulated supply frequency. Follow the wiring instructions carefully. Surely the challenge you are having will be overcome.
06/20/2013 12:00 AM
Dear Mr.jhunair,
The data given by you is not sufficient to understand the problem. Pl. post the following information .
1. What is the need for VFD for submersible pump.? Whether it is 6 Pulse or 12 Pulse.?
2. Is there Harmonic Filter installed.?
3. What is the detail for earthing.?
4. Whether the Motor is suitable for VFD application, such as Bearing Insulation or Insulated Bearing.?
5. Whether De-Rating Factor is considered as applicable.?
6. What is the distance between the Drive and the Motor i.e the cable length.? Whether the cable is grounded.?
7. Whether the Blower inside the VFD installed has adequate capacity.?
Once these details or known we can think of a solution.
DHAYANANDHAN.S
06/20/2013 7:22 AM
Additionally, submersible pumps have lower efficiency than conventional motor-pump groups (stator windings work under water, thicker wire insulation, aspect ratio not ideal). So 50 hp means higher electrical power. Check measured kW and amps vs. VFD spec.
Also the hydrodynamic bearings are not designed for lower rpm, so a soft starter suits best your application.
06/20/2013 9:15 AM
Sorry, what I mentioned above for the bearings vs. rpm applies to vertical well pumps, not for submersibles.
06/20/2013 11:18 PM
Hi,
The RVAT is for starting purposes and nothing else. VFD is for those system that needs variation in speeds and torques.. So, what is your requirement? If for starting only then you need a soft starter..
06/21/2013 6:19 PM
Hello Sirs,
Thank you very much for your inputs, we put back again the RVAT starter because the vfd causes us problems we need full speeds since the demand of water is large.
Register to Reply 13 comments
bigg (1); BOLARINWA GBENGA J (1); dhayanandhan (1); jhunair (1); jimmydetectors09 (1); JPool (1); lyn (2); namierequina (1); PWSlack (2); Snel (2)
