Previous in Forum: How to Adjust Power Factor When Two Generators Are Running Parallel   Next in Forum: Voltage Drop
8 comments
Connecting Generator and PCC
06/26/2013 8:00 PM
we are going to install 2.8 mw generator(TPP)440v 50Hz.The Pcc where this will be syncroniced with grid is 100 mts away.Pl let me know the following :
1) whether to use Bus duct or cables
2)what are the protection devices and relays to be adopted
thanks and regards
Good Answers: 104
Re: Connecting Generator and PCC
06/26/2013 8:15 PM
You are kidding, right?
Good Answers: 181
06/26/2013 9:54 PM
I'm sure someone will help for a suitable fee.
Anonymous Poster #2
06/27/2013 2:31 AM
Are you the designer for the project? Do you even understand the enormity of the requirements? If you are the in-charge, god save the project from any calamity. Are you planning to synchronise at 440 Volts level? Do you understand the quantum of current you will be dealing with?
Please get on board a power consultant ASAP to get an idea of basic raw data you need before you can even think of starting design.
06/27/2013 3:05 AM
06/27/2013 1:29 PM
Are you the installer, or the customer?
If you are the installer, hire an electrical engineer.
If you are the customer, run away from this installer as fast as you can and hire a competent installer.
06/27/2013 2:57 PM
Words fail me.
Hire someone qualified to perform this work.
Good Answers: 170
06/28/2013 10:34 PM
If everything could be instructed thro forums, then how consultants would earn a living?
06/29/2013 2:59 AM
Good Answer sir.
Anonymous Poster (1); bigg (1); electricalexpert65 (1); jack of all trades (1); lyn (1); Pattabhiraman (1); PWSlack (1); TonyS (1)
