Previous in Forum: How to Calculate Incomer Breaker Sizing for a 3 Phase 4 Wire 415V 50Hz UPS DB   Next in Forum: Are ExnA Type Motors Waterproof?
Parallel Operation
06/30/2013 5:01 AM
during parallel operation of generators why slightly high incomming speed and voltage?
what is the reason?
Re: Parallel Operation
06/30/2013 10:55 AM
Because as the incoming generator takes on load, its speed and voltage will decrease slightly to match the other generators.
Engineering Fields - Power Engineering - Thermal Power Plant Electrical Engineer
06/30/2013 4:20 PM
Voltage and speed should be higher...Because current flow will there when there is a potential difference, in order to maintain it voltage will set somewhat higher than grid valve before sychronization.
Register to Reply 2 comments
