Previous in Forum: Parallel Operation   Next in Forum: Tips to Convert a Universal Motor to a DC Generator
16 comments
Are ExnA Type Motors Waterproof?
06/30/2013 11:12 AM
Good Day, sirs!
I would like to ask a question regarding to the type of motors. Recently, I was informed that according to IEC 60079-14, ExnA type motors can be used Zone 2 area according to Hazardous area classification. My concern is what would be if we use this kind of motors in Zone 2 area and are they waterproof? Any additional information regarding to this type of motor is welcomed.
Thanks in advance,
Respectfully,
Kidirbay Kaypnazarov
John
Pathfinder Tags: Non sparking
Re: Are ExnA type motors waterproof?
06/30/2013 11:23 AM
Doesn't anybody know how to Google?
Hazardous Areas Motors - Weg
Define: waterproof. Waterproof according to what? NEMA? EN / IEC 60034-5?
What does your motor vendor say?
If a gas can't get in, how will water?
06/30/2013 11:43 AM
Dear lyn,
there is a powerful tool - Google, I have searched, but there were too many information about this type of motors, could not find proper answer to my question, also I am not an electrical specialist.
Anyway, thanks for your answer, as a waterproof I have meant that if there is any damage for running motors from fire extinguishing system(sprinkler or drencher).
John
06/30/2013 11:50 AM
all kidding aside I know English isn't your 1st language but if you ask your question a little more clearly and completely maybe someone can offer you information you can use. "running motors off of a sprinkler system" doesn't make sense to me, sorry
06/30/2013 12:03 PM
And did you pose this question to whomever "informed" you in the first place?
I don't know if you can specify a "washdown" grade motor for hazardous applications, and I would never attempt to specify a motor without knowing if it is capable of performing according to the applicable specifications. That would be unethical.
What's your excuse?
Why don't you ask your motor supplier to do your job for you?
I'm fed up with incompetent people coming here for free advice, while being paid by someone who assumes that they are competent to do the work!!!!!
Where are your ethics?
06/30/2013 9:52 PM
lyn,
by answering this question you did not discover America, this is just one of the simplest questions! If you think that you are competent person, just do not answer for such questions and do not give free advise for "incompetent people"!
John
06/30/2013 10:30 PM
From Lyn's source:
The Ex nA motor enclosure is built identically to a safe TEFC motor.
This may not be as fully water resistant as a "washdown" motor, but may suffice for your application. Please consult local electrical code officials.
07/01/2013 3:25 AM
Non-electrical-specialists should not be designing, specifying, acquiring, installing, testing or maintaining hazardous area electrical equipment without having first received appropriate training for the task.
So stop work. Either delegate the task to someone who is a specialist, or attend a training course without delay.
06/30/2013 11:41 AM
one sure way to find out...fill a bathtub with water, jump in lower the motor in the water and turn it on......please report back with your results
06/30/2013 12:18 PM
Good Day, sirs!
Thanks in advance
06/30/2013 3:06 PM
Who did your work last week?
Good Answers: 141
Re: Are ExnA Type Motors Waterproof?
06/30/2013 10:07 PM
Waterproof is not enough as specification. Need atmosphere, bar, psi numbers or depth.
Also a motor that performs well in Ex zone has not always the correct materials to be submerged in water, especially salt water.
As Lynn says, it will work in water, just do not know for how long.
Plenty of room here
06/30/2013 11:33 PM
No.They are not. The clearances wod the wires is set to a minimum, but do not make them water proof. Water proof motors have a mechanical seal for the shaft, and a gland that makes the cable entry totally weather proof.
Good Answers: 141
07/01/2013 12:18 AM
So is the EX version, unless it is a nitrogen fed casing.
Plenty of room here
Good Answers: 117
07/01/2013 1:27 AM
Water proof motor? No, just because it has an Ex rating does not make it water proof. Many people believe that Ex means that it is gas proof, that is there is no gas inside the unit or gas is prevented from entering, again that is also wrong.
Ex rated equipment and depending on the rating, means that something goes wrong with the unit, in your case the motor, then the unit will be able to suppress any further ignition, in the case of a short circuit.
Your motor MAY BE moisture proof, but not water proof, and as previously mentioned.. give the motor manufacturer a call or read the tech specs.
As for its suitability for Zone 2... again see what your motor manufacturer specifies
Good Answers: 25
07/01/2013 6:44 AM
For water proofing motor you will need IP55 protection for motor. Along with Hazardous protection.IP55 protection is for hose proof motors.
07/01/2013 4:25 PM
Thank you for posting this question, It is an interesting one
To answer the question..Unnecessarily
Waterproofing ( Rain, water jet, sprinkler system etc.) should be verified by motor nameplate data, factory inspection and testing report and certification i.e looking at IP degree or Nema enclosure type
Register to Reply 16 comments
Anonymous Poster (1); brich (1); Candlez (1); dvmdsc (2); Fredski (2); Gadepalli Subrahmanyam (1); k.kaypnazarov (2); lyn (3); PWSlack (1); suresh sharma (1); Tornado (1)
