Previous in Forum: Turbine Governor Servomotor Problem   Next in Forum: 350 kVar Capacitor Bank
Parallel Transformers
07/01/2013 1:18 AM
A new plant powered through 5 main, 30 MVA Transformers connected in parallel. Out of these 5 transformers, How many transformers should usually be considered as a standby ?
what is the Firm Capacity of the 5 parallel Transformers
Any comment or link is appreciated
Re: Parallel Transformers
07/01/2013 2:02 AM
Try googling "homework sites".
07/01/2013 2:08 AM
It should have 1 on standby. As the other 4 shall be load with n+1
07/01/2013 3:21 AM
It depends on how the installation is intended to be run, about which no information is available here. How about the HV Electrical Engineer that designed it? Even if the individual is unavailable, the design brief document should exist somewhere.
07/01/2013 8:42 AM
You have a brand new power plant and you don't have any engineering documents or access to an engineer or electrician. I don't believe you.
07/01/2013 9:41 AM
Homework!
At least let's hope it's homework.
Pity the poor people depending on power from this new plant with no competent operators.
07/02/2013 12:16 AM
What is the connected load,average load,maximum load,load factor,diversity factor etc,are there any critical loads(kVA),have you installed standby generators(kVA),give details.
pnaban
07/03/2013 3:33 PM
Please read the CR4 rules as this is not a homework cheat site.
Reply Score 1 for Off Topic
jack of all trades (1); Lek (1); lyn (2); pnaban (1); PWSlack (1); redfred (1)
