Previous in Forum: 100KVA Generator Proper Grounding   Next in Forum: "Photonic Fence" Laser Wall Mosquito Defense
FD, SA, and ID Fans in a Steam Power Plant
07/14/2013 8:59 PM
Helo! Please help me. Please explain in understable way how does SA, FD, ID fans work in steam power plant?
Looking forward to your answers!!
Thank you very much!!
Good Answers: 104
Re: FD fans SA fans and ID fans
07/14/2013 9:21 PM
SA - secondary air (provides secondary combustion air)FD - forced draft (provides air under pressure to burner/boiler)ID - induced draft (draws air out of boiler to maintain draft/negative pressure in the boiler)
A boiler may have no fan, FD fan only, ID fan only, or both FD and ID fans.
here's a link from several years ago discussing primary and secondary air:http://cr4.globalspec.com/thread/51131
Re: FD, SA, and ID Fans in a Steam Power Plant
07/14/2013 9:24 PM
Generally, FD fans push air into and through a process; ID fans pull air through a process and discharge it to atmosphere. SA = supply air, which is usually pushed. (If pulled, it is normally called exhaust air.)
These terms are not necessarily universal.
07/14/2013 9:27 PM
Look for answers before you post. Search CR4 or use a search engine to see if you can find the answer to your question.
ABC OF THERMAL POWER PLANT: ID,FD,PA FANS FOR BOILER ...
Engineering Fields - Power Engineering - Thermal Power Plant Electrical Engineer
07/15/2013 9:25 AM
In any boiler we have to maintain balanced draft(with negative and positive drafts) is the basic...PA Fan will provide air for combustion of coal which is positive draft to compensate it ID Fan will provide negative draft. SA FAn will provide EXCESS AIR, which will be required for the COMPLETE combustion of coal without any unburnt. IN CFBC Boilers, Secondary air will also be used in fluidization process as Tertiary air.
Register to Reply 4 comments
bigg (1); itsphani99 (1); lyn (1); Tornado (1)
