Previous in Forum: Servo System Selection for Injection Molding Machine   Next in Forum: Bolt Opening Torque Mis-Conception
Atlas Copco Dryer BD1056
07/16/2013 4:40 AM
DEAR MEMBER
I have One Atlas Copco Air Dryer Model BD1056 i face problem on this dryer on running condition the outlet Temp is very high plz help me
Best Regards
RAJA GHULAM KIBRIA
Re: Atlas copco Dryer BD1056
07/16/2013 4:41 AM
What does <...very high...> mean in terms of product temperature and ambient temperature? Why is this a problem? What is going through it? At what rate is this stuff going through? How does that compare with field trials that took place before the equipment was purchased? What is the utility consumption? How does that comapre to the field trial data?
What does Atlas Copco's local Service Technician have to say on the topic, and why can't that individual either eliminate the problem or at least make recommendations? Why have the recommendations not been followed-up? What do the maintenance records say?
07/16/2013 4:57 AM
Unfortunately there is no Good Questions button for the answer field.
It's very helpful questions you bring up there. Also since it was only one of us asked to help and you just did I will refrain from and almost because of completeness of your "answer" I don't have to, comment anymore!
07/16/2013 5:07 AM
It is very difficult formulating a useful response from the paucity of solid information in some of these threads. There are usually loads of questions, and, well, someone has to ask them as the Original Poster seems to want that rather than a speedy response with which to solve the original problem. Of course, after a while, readers get fed up and move on.
Re: Atlas copco Dryer BD1050
07/16/2013 11:25 AM
Dear sir
dryer condition is normal in running parameter ambient Temp is 45C' and air inlet temp 25c' Heater temp 100c' to 120c' air outlet temp 80c' to 80c'
this dryer instal with water could Air compressor if you have BD1050 dryer plz send me running parameter
Good Answers: 104
07/16/2013 11:41 AM
According to this brochure, this is a heat-reactivated dessicant adsorption air dryer with internal electric heaters and a self-contained regeneration blower.
Make sure the heater is turning off at the appropriate point in the regeneration cycle and staying off during the drying period.
07/16/2013 5:16 AM
If this is a refrigerated type of dryer, I would check the condenser for dust accumulation or other air flow restriction.
What temperature is actually high? Air side or refrigerant side?
Re: Atlas Copco Dryer BD1056
07/19/2013 7:26 PM
Register to Reply 7 comments
bigg (1); IdeaSmith (1); lyn (1); PWSlack (2); raja8866 (1); Tornado (1)
