Previous in Forum: Bolt Opening Torque Mis-Conception   Next in Forum: API 5L Minimum Temperature
8 comments
Large Diameter Flange Design
07/17/2013 2:30 AM
i have a large flange having inner dia 2780mm , can any one suggest me how to design it???
Good Answers: 18
Re: large diameter flange design
07/17/2013 3:37 AM
How?
You've given absolutely no information.
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
07/17/2013 3:38 AM
Yes, indeed. The following questions will need answers during the design:
  • What is the maximum pressure difference?
  • What are the maximum temperature swings?
  • What are the wetted materials of both flange and joint?
  • What is the thickness of both the flange and the [whatever it is to be attached to]?
  • What is the pitch circle diameter?
  • How many bolts?
  • What size bolts?
  • What length bolts?
  • What is the torque setting?
  • How is the flanged item to be supported while being lugged into and out of place?
  • What is the test regime to be imposed following assembly?
  • Etc.
Good luck with the design.
07/17/2013 4:17 AM
What colour do marketting want it?
Good Answers: 104
07/17/2013 8:03 AM
* What is this flange to be used for - part of a pressure vessel?
* What codes must the flange and final assembly meet?
07/17/2013 8:31 AM
Dunno. Ask ASHISH-RAWAT instead.
Good Answers: 104
07/17/2013 2:54 PM
I just put it there as a continuation of your list. Doesn't seem to matter - OP seems to have gone missing (I hate that phrase).
Good Answers: 183
07/18/2013 1:01 PM
I always appreciate your question list but this time you ask for data about dimensions and other information which are the RESULT of the design and cannot be given before it even starts. I am a bit surprised.
07/17/2013 4:58 AM
Hire a knowledgeable designer.
Register to Reply 8 comments
bigg (2); jesw55 (1); nick name (1); PWSlack (2); Tornado (1); user-deleted-1105 (1)
