Previous in Forum: How to Profit from Data Collection   Next in Forum: ClO2 (Chlorine Dioxide) Home Water Injection
Effect of Temperature on Dew Point of Nitrogen
07/20/2013 12:18 PM
Can any one give me a link to the effect of temperature on dew point of Nitrogen.
Re: Effect of temperature on dew point of Nitrogen
07/20/2013 12:31 PM
07/20/2013 1:03 PM
I dont know, If I really push myself to the limit it might take me all of 3 seconds to Goggle that
Re: Effect of Temperature on Dew Point of Nitrogen
07/20/2013 4:22 PM
It would be easier to determine the effect of pressure on the dew point of nitrogen, as the dew point is actually a temperature.
Good Answers: 58
07/21/2013 6:48 AM
You may want to clarify your question. In a sealed container, the dew point of nitrogen (or any gas) doesn't change. So, if your container of nitrogen is at a dew point of 10 degrees C, and you increase the temperature from 20 degrees to 50 degrees, the dew point remains at 10 degrees. The reason for this is because the dew point is actually the concentration of water molecules in the gas, and that remains constant with temperature.
07/22/2013 5:43 AM
Thank you sir, for the clarification
07/22/2013 9:23 AM
1) This has to be inreference to the water content of N2 gas. As such, the water content determines the dew point, and overall system pressure has a bearing on this, as equilibrium vapor (water) pressure is affected by changes in mechanical pressure. [Look this up in a thermodynamics or physical chemistry book].
2) Temperature only matters in the sense that the system is above or below the dew point of this wet gas.
3) The actual water content of the gas has a direct influence on the dew point.
Register to Reply 6 comments
avadiraja (1); Fredski (1); James Stewart (1); lyn (1); PWSlack (1); welderman (1)
