Previous in Forum: What are the Harmonic Frequencies of the Sodium Ion?   Next in Forum: Density of Helium
12 comments
Good Answers: 22
Sealant for Potable Water
07/22/2013 10:02 AM
I have a need for a sealant that would seal between a tygo type tube and probably ABS plastic in which a hot potable water is used. This is on a hot water pump for a camper and the water is probably around 175-180 F. The pump is rated for hot water (212F) and potable use and has 1/4 inch OD non barbed smooth fittings. I am assuming the plastic is ABS but am not sure. It is black. I have tried worm clamps and spring clamps but have not gotten a seal that can withstand even 6 inches water head. The leak seems to be independent of clamping force or water pressure so I believe it is capillary action which will require a sealant to stop. The maximum pressure that the pump can deliver is limited to about 28 PSI. The only sealant I have found that advertises the needed requirements is not available locally or in small quantities (or at reasonable cost)
Can anyone suggest a solution. Teflon or greases are out since that would lubricate the joint and allow the tube to slip off.
I would be willing to change to a different type of tubing, if I could find something that was rated for this temperature and could be clamped to smooth fitting. The input and output tubes are close together so the thickness of the tube and any clamp is limited to about 3/32 inch. Most of the hose rated for this temperature is hard or thick.
Pathfinder Tags: potable sealant
Re: Sealant for Potable Water
07/22/2013 11:45 AM
07/22/2013 11:58 AM
1. Make/model# of pump?
2. Can the fittings be changed out for barbed fittings?
3. You really need to know what materials of construction are in this pump.
4. How was it done at the factory?
5. Not crazy about using cyanoacrylates, unless the are medical grade.
6. Maybe a silicone?
Good Answers: 22
07/22/2013 2:27 PM
The fittings are cast into the pump body and cannot be changed.
I am pretty sure the pump is ABS
Very little silicone meets potable water standards. Those that do are not available is small quantities or locally.
The pump manufacturer says to use a clamp and smaller tubing and force it on. They said the pump material is a type of nylon, but food grade. They advised no sealant but said it must be food grade if I chose to use one. I was lucky to make a contact that could type English, although it was obviously not his first language. I will try to find a tube that is less than 1/4 but greater than 3/16 which will not fit. 5 or 6mm would probably work if I can find it.
07/22/2013 12:00 PM
Good Answers: 266
07/22/2013 12:56 PM
I have had problems in similar applications. I find on many its not the pressure or the clamping force. It's the seam on the fitting where the die halves were off set or a crack in the fitting. I would replace the fitting not the hose. Find a good compression fitting for plastic hose.
Good Answers: 203
07/22/2013 11:43 PM
What about either scraping or filing the mold flashing off the fitting so it didn't leak due to this. I have used this numerous times to get tight fits on plastic fittings.
Also consider filing a small shallow notch all around the fitting near the hose end to give the tubing and clamp something to "hold onto". This would be similar to the fittings used for polyethylene plastic tubing for lawn sprinklers and wells but with far fewer barbs.
Also consider using reinforced vinyl tubing instead. The woven reinforcing will give it much more strength and higher temperature tolerance.
I have used these tactics at one time or another and they worked. Sometimes for an emergency and sometimes for permanent installations. Most of the emergencies installs ended up being permanent due to forgetfulness or laziness.
Good Luck, Old Salt
07/22/2013 3:01 PM
You could make things much easier for the forum if you'd publish your location.
It can be added to your profile.
07/22/2013 10:44 PM
If this is for hot water, you are likely not drinking it, so why the food grade requirement?
Have you considered reforming the end of the fitting with a bit of heat to get a barb type arrangement on it?
Can you build up the outside surface of the fitting with a suitable epoxy that will adhere to the fitting, form a barb type shape into this epoxy, and then fit a suitably upsized tube?
Good Answers: 22
07/23/2013 12:26 AM
The water will be at the kitchen tap for the hot water. There is not enough room between the inlet and outlet of the pump to add a barb. I tried 3/16 tubing and it appears to work if I can also get it over the barbed 1/4 fitting at the other end of the tube. I am going to try to clamp with a double wrap tie wrap the way a lot of newer Japanese car are doing nowdays. I've tried it on radiator hoses and had success, but they only get to 15psi or so. This pump develops about 28 psi. Ironically it doesn't seem to leak anymore at pressure than just sitting with no pressure. For those who have thought a problem might be a flash or casting mark at the fitting, that is not the case, the fitting is smooth. With the small diameter, I have had no problem with the tube coming off, it just slightly seeps is all. I was able to get a seal with the 3/16 tube that didn't leak. I did find out that the local hardware can get a sealant that is food grade without costing me shipping. If I need it, I will order that, but right now I think I can get a seal without it.
07/23/2013 4:41 AM
It does seem a little odd to be boosting the hot water for a kitchen sink and then using only 3/16in tubing to get it there, however, noted that this is for a camper connection..
  • For a fixed installation one might use a single- or double-impeller mains-operated shower pump with a decent-sized connection for the tap/faucet. If the unit were installed in the UK, 15mm copper pipe would be one of the many ways of getting there, and most shower pumps have a BSP screwed fitting that accepts a flexible hose connector with a push-fit connection on the other end for the copper pipe. http://www.screwfix.com/c/bathrooms-kitchens/shower-pumps/cat820270 (usual disclaimer).
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
07/23/2013 7:30 AM
A silicone sealant for fish tanks is safe,reasonably priced and available at most pet shops in small tubes. I have used this on the plumbing in my RV with success.
Nothing is fool-proof to a talented fool
Good Answers: 22
07/23/2013 10:43 PM
Our town has no pet shops. Thank you for the tip, I will keep it in mind.
Register to Reply 12 comments
4wsilver (3); Anonymous Poster (1); bwilko (1); lonster (1); lyn (2); old salt (1); ozzb (1); PWSlack (1); SolarEagle (1)
