Previous in Forum: Sealant for Potable Water   Next in Forum: Steel Oxide Composition and Thickness Measurement
9 comments
Density of Helium
07/22/2013 10:44 AM
What Is the density of helium gas at room temperature?
Re: Density of Helium
07/22/2013 11:51 AM
It's a good topic for a search engine such as Google. It would be best to have the pressure handy as well during the search as, being close to an Ideal Gas, Helium's density and pressure are almost linearly related to each other at constant temperature.
07/22/2013 12:19 PM
Density: 0.0001785 grams per cubic centimeter...
http://education.jlab.org/itselemental/ele002.html
07/22/2013 4:55 PM
Even more important, the pressure must be specified.
07/23/2013 9:37 AM
Given the lack of information here it can only be determined that He at room temperature will be the second least dense gas possible.
DO YOUR OWN HOMEWORK!
07/23/2013 9:55 AM
What happened to the other thread?
07/23/2013 10:01 AM
Safe to say that intelligent life is still missing.
07/23/2013 10:05 AM
07/27/2013 7:55 PM
Density is a relationship between mass and volume. The volume of a gas is not constant, you need more information before you can solve this. The gas will expand to fill whatever volume it can. Got a specific volume in mind?
Rose
07/28/2013 5:11 AM
If you are thinking about it as an ideal gas you need to know pressure too. Pressure and volume are inversely proportional when it comes to an ideal gas.
Rose
Register to Reply 9 comments
Doorman (2); Goewin Rose (2); lyn (2); PWSlack (1); SolarEagle (1); Tornado (1)
