Previous in Forum: Final Max Output Torque of a Gear Drive   Next in Forum: Suction Center for Metering Pump
9 comments
Non-Reverse Ratcheting for Existing US Motor
07/24/2013 3:31 PM
Is it possible to install a non reverse ratching for existing (not new) 1750 HP US Motor 900RPM, 4160 VAC vertical turbine pump Peerless?
Re: NON REVERSE RATCHING FOR EXISTING US MOTOR
07/24/2013 3:35 PM
ratcheting, perhaps?
Non-reverse???? Does this mean that you don't want the pump to rotate backwards when not running?
More explanation.
07/24/2013 3:54 PM
07/24/2013 4:06 PM
You should talk to U.S. Motors, or a pump service company.
U. S. Motors seems to like their, "The BALLOMATIC backstop".
Call a service company.
Good Answers: 104
07/24/2013 4:07 PM
I'm sure it's possible. Contact US Motor with Model #, Serial #, pump specifics and see what they say. If the pump column isn't too long, perhaps you could accomplish the same thing with a check valve or automatic valve?
07/24/2013 4:30 PM
I did. I am waiting answer of US Motor. I only want to know if anyone have had experience doing it.
Thank you very much.
07/25/2013 3:14 AM
<...waiting answer ...>
No. Mistake. Don't wait. Don't use e-mail, because it can be ignored. e-mail is low-priority communication.
Be a pest instead. Use the TELEPHONE. It's quicker. It's two-way. There's a person on the other end. It's about relationships.
Re: Non Reverse Ratching For Existing US Motor
07/25/2013 3:16 AM
What - so there's no non-return valve in the line, then? How did THAT get through HazOp?
07/25/2013 6:59 AM
07/25/2013 8:01 AM
I don't know, and there is no way anyone else could know if I don't, so you'll have to call a service company. Oh wait, Lyn already said that. Your welcome.
Register to Reply 9 comments
Anonymous Poster (1); bigg (1); JUAN-PANAMA (2); lyn (2); PFR (1); PWSlack (2)
