Previous in Forum: Non-Reverse Ratcheting for Existing US Motor   Next in Forum: Water Content In Air Line
Suction Center for Metering Pump
07/25/2013 1:50 AM
I would like to know where is the suction center of metering pump for hydraulic calculation. Please refer to the photo of metering pump below. A? B? C? or other point??
Re: Suction center for metering pump
07/25/2013 2:17 AM
I vote for B, but how would the differences among A, B, and C be significant?
07/25/2013 9:20 AM
I 'd say the same. The difference is negligible. After a bit of research on my side this seems to be the definition of the center of the suction line when in a horizontal arrangement.
Good Answers: 18
07/25/2013 4:37 AM
Hi JBK,
Can you see through from A to C if so they are the same port (sorry if I am stating the glaringly bleeding obvious).
B doesn't look like a port!
Is the port on the opposite side the outlet?
Just a thought but could A B & C be connected and b be a relief valve.
Sorry it's just more questions.
Best of luck,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
Re: Suction Center for Metering Pump
07/25/2013 12:40 PM
"hydraulic calculation" of what?
What is a "suction center"?
Thought I'd throw this in for kicks: The Suction Center,
United Kingdom - Member - Not quite retired Member
Location: Up an araucaria araucana tree, South London, United Kingdom
07/26/2013 5:17 AM
I suggest the suction flange for suction side calculations and the discharge flange for the discharge side BUT, if the pressure drop in that sharp access bend turns out to be significant then include it and go for B.
First thing, then. calculate the drop in that entry bend, to see is it matters. Next is to check the height above the suction level to ascertain Net Positive Suction Head (NPSH).
07/26/2013 10:02 AM
I love the picture in the middle of the presentation where everybody is in HazMat suits and the one guy is in shorts and a pink polo shirt.
1. What does this picture have to do with the presentation? - I'm guessing that the author wanted to poke fun at a colleague.
2. Was the picture photoshopped? - I'd like to believe that it was, but I'm guessing that it wasn't.
"Obviously you're not a golfer." - The Dude
07/26/2013 10:50 AM
Suction center (as well as discharge center) is naturally point B, that is where the suction (as well discharge) takes place.
Talking of suction, the distance BC could be anything depending up on the individual design, few centimeters or few meters (if there a threaded nipple instead a flange).
What is important is the suction head, which is the static suction head above the center line (of the pump/piston) minus the pipe friction (including the friction losses of all fittings).
Register to Reply 7 comments
Geoffrey36 (1); IdeaSmith (1); jesw55 (1); lyn (1); pauls_14 (1); Tornado (1); yesyen (1)
